  2. Adams Car
  3. Linking ADAMS/Car with ADAMS/View
  • Replies 12
  • Subscribers 1
  • Views 25
jsph_inc
jsph_inc over 2 years ago
Hi All,
Apologies if this has already been documented or discussed. I did a search but did not find anything on the topic.
What is the method(s) to link an ADAMS/Car model with an ADAMS/View model?
The only way I can think of is bringing both into Simulink and performing a cosimulation.
Is there a direct way within the ADAMS environment of doing this?
joe.
  • MK202610123211
    0 MK202610123211 over 2 years ago
    Why use a complicated FMU approach, when a simple "file command read" + "model merge" would do the job of reading an A/View model into an A/Car model ?
    Seriously: A/Car is just a customized A/View. You can easily merge these models and then connect the necessary joints/forces/solver variables.
    You could even "transform" a View-model into a Car-template by creating a blank template read the view-cmd and merge with the template. You'd then need to add communicators to connect to other subsystems.
  • jsph_inc
    0 jsph_inc over 2 years ago
    Hi Martin,
    Thanks for the suggestion! I may go this route as it could be more stable from a solver perspective then FMU.
    joe.
