  2. Adams Car
  3. Static equilibrium analysis problem.
  • State Verified Answer
  • Replies 7
  • Subscribers 1
  • Views 2
SamsonAkash
SamsonAkash over 5 years ago
I am trying an H-arm Camber link suspension type, but I get an error like this "Static equilibrium analysis has not been successful". I checked the constraints with other templates but I couldn't find mistake I had done. Can someone please help me to sort it out this problem.
Attached Files (4)
Rear_subsystem.sub.zip
trail_1_parallel_travel.msg
_H_arm_suspension.tpl.zip
Rear.asy.zip
  • Jesper Slattengren
    0 Jesper Slattengren over 5 years ago
    If you run a dynamic suspension analysis (dynamics are less tricky to get through than statics), you will see that your strut is not properly attached. Not at all at the bottom and something wacky at the top.
    The wacky thing was that your top mount joint was active only in kinematic mode so it was deactivated by default.
    To summarize:
    1. Create a joint between lower strut at H-arm. Spherical is ok if you change the cylindrical joint between lower and upper strut to a translational.
    2. Change the hooke joint at the top of the strut to be always active.
  • SamsonAkash
    0 SamsonAkash over 5 years ago
    Thanks JSlat, I tried what you mentioned above and I got the result but I got some warning like this "Residual imbalance is less than 0.00000E+00" and
    acar/svsl
     *** Warning:
    the left side rotation is equal to zero.
    therefore, the side view swing arm length will equal zero.
    acar/svsl
     *** Warning:
    the right side rotation is equal to zero.
    I don't know what is the problem. Can you please help me in this warning.
    Attached Files (1)
    opposite_wheel_travel_1.zip
    The second warning you can ignore (it was actually discussed here only a week ago). But it is because there is no flexibility in your suspension, so ADAMS can't calculate compliance terms. You could switch to using geometric method instead of compliance method, but better is to add some bushings that represent the stiffness of your real joints (so very stiff, but not ideal rigid).
  • SamsonAkash
    Ohh Ok, then i will try giving bushing in joints but i used geometric method in the above template, but i like to ignore those warning and i think this would not affect my full vehicle assembly. But i will try using bushing in my joints and try other analysis. Thanks JSlat for taking your time for me.
