  2. Sigrity
  3. IR Drop Workflow
  • Subscribers 22
  • Views 13061
IR Drop Workflow
DBTCH
DBTCH over 5 years ago
Hi All ,
Actually i use Allegro PCB designer 17.2 S068 with High speed option  and I see here that normally the IR drop workflow is available .
But i can't select anything on the menu , select power tree is grey .
Do i need an upgrade , install a another tool (Sigrity ) ?
Thank you for your help .
David
  • RFinley
    0 RFinley over 5 years ago
    Yes.  Install Sigrity2021.  None of the apps work without a license but the (impedance and crosstalk) workflows start working.
  • Akulin
    0 Akulin over 5 years ago
    No, you can't run the simulation of IR Drop in Allegro+High Speed Option. You can only load and observe the results of simulation.
    To run the simulation, you need the Sigrity Aurora license which may be probably not too expensive because there are some promo prices for it.
    Or you need some Sigrity licenses.
  • RFinley
    0 RFinley over 5 years ago in reply to Akulin
    thanks for the clarification.  IR drop would be the only thing I could justify adding high-speed for at my current job.
  • DBTCH
    0 DBTCH over 5 years ago in reply to Akulin
    Thanks , so I need to request a Sigrity Aurora license Slight frown
