  2. Sigrity
  3. How to Use AMI and DLL Files with IBIS Model in Topology...
  • Subscribers 21
  • Views 11064
How to Use AMI and DLL Files with IBIS Model in Topology Explorer (TopXp) tool
SimTech
SimTech over 4 years ago
There are two methods to assign *.ibs,*.ami, and *.dll to do channel simulation.
Method 1:
 You can add the *.ami/*.dll model on the canvas directly in TopXp. Select Tx or Rx, right-click on the Tx or Rx block and select Add AMI.
The AMI bubble will be added to the Tx/Rx block.
Method 2 :
You can add following [Algorithmic Model] statement inside the *.ibs file and call *.ami and *.dll model files in the ibis file.
[Algorithmic Model]
Executable
Windows_VisualStudio2015_64 NameOfAMIModel.dll NameOfAMIModel.ami
[End Algorithmic Model]
[Algorithmic Model]
Executable Windows_VisualStudio12.0.31101.00_64 pcie5_Rx_licensed_win64.dll pcie5_Rx_BCI_licensed.ami Executable Linux_gcc4.1.2_64 pcie5_Rx_licensed_rh64.dll pcie5_Rx_BCI_licensed.ami
Here, an older version of Visual Studio, VisualStudio12.0.31101.00_64, is used.
Click here to know more detail on this.
Team SimTech
Cadence Design Systems
  • SimTech
    SimTech over 3 years ago
    Further you can refer to the below techniques on how to use the ibis model along with ami and dll/so files in TopXp Channel Simulation:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AHI6aEAH&pageName=ArticleContent&utm_source=ami+dll+channel+simulation_10042023&utm_medium=Internal&utm_campaign=Sigrity
