  2. Sigrity
  3. What is the virtual package in the PowerDC? thanks.
  • Subscribers 21
  • Views 9357
ShawnLiTiger
ShawnLiTiger over 4 years ago
Hi Team,
Have a good day!
I used Cadence 17.2 and designed a PCB board, then I imported this design into the Sigrity 2022 PowerDC tool. there had some virtual package(U10) in the work window, the real component location is position 2. I`d like to know what the virtual package U10, how to correct this problem? which tool should I fix it in PCB editor or PowerDC? would you please share some hints with me? thanks.
Br,
Shawn Li
TRANSLATE with x
English
Arabic Hebrew Polish
Bulgarian Hindi Portuguese
Catalan Hmong Daw Romanian
Chinese Simplified Hungarian Russian
Chinese Traditional Indonesian Slovak
Czech Italian Slovenian
Danish Japanese Spanish
Dutch Klingon Swedish
English Korean Thai
Estonian Latvian Turkish
Finnish Lithuanian Ukrainian
French Malay Urdu
German Maltese Vietnamese
Greek Norwegian Welsh
Haitian Creole Persian
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
  • jillashiva
    0 jillashiva over 4 years ago
    Hello Shawn , How did you translate the *.brd file to *.spd format ? Now Power DC supports the direct translation of the *.brd file format to *.spd file format  i.e., you can load the *.brd file directly.  you may give a try to rule out the translation issue.
    Cheers,
    Shiva
  • ShawnLiTiger
    0 ShawnLiTiger over 4 years ago in reply to jillashiva
    Hi Shiva,
    Thanks for your response!
    I loaded my design board file directly in the sigrity tool, is it not appropriate for the translation? my design board was drawn by allegro.
    Br,
    Shawn Li
    TRANSLATE with x
    English
    English Korean Thai
    French Malay Urdu
    TRANSLATE with
    COPY THE URL BELOW
    Back
    Back
  • jillashiva
    0 jillashiva over 4 years ago in reply to ShawnLiTiger
    Hello Shawn , you can give a try by unchecking the options below
    you can find these translation options  from Tools >Options> Edit options ..
    Try unchecking these options before you load the board file in to the Optimize PI 2022
    Cheers,
    Shiva Prasad
