  2. Sigrity
  3. Connectivity Checking in Topology Explorer
  • Subscribers 25
  • Views 9959
SimTech
SimTech over 4 years ago
In Topology Explorer, there is a function which allows for a quick check between the Rx and Tx block. This is usually done before the Bus Simulation to make sure all the connections are placed correctly. This can be done by clicking on Check Connectivity in the SystemSI Workflow.
The Connectivity Checker window will open in the bottom of the TopXp window. Click on Check to run the Connectivity Checker.
The results shown above show that all of the connections in this example satisfy the check , Average magnitude is close to 1 signify there is a good connectivity.
Team SimTech
Cadence Design Systems
  • KellyP
    KellyP over 4 years ago
    I didn't know I can do this using topology explorer.
    tdiu permanent and total lawn care marketing expert marketing agency
  • jillashiva
    jillashiva over 4 years ago in reply to KellyP
    Yes, this is a nice tip to check the connectivity before to run the simulation, this ensures all the blocks are connected properly in the topology!
  • DDRsvi
    DDRsvi over 3 years ago
    Hi bro,
    Please help me on this issue
    How to fix connectivity of Net which it can not connect to other pins? Like as picture
  • jillashiva
    jillashiva over 3 years ago in reply to DDRsvi
    you will have to make sure if the Block has the correct Ports and connected to the other Block
