  2. Sigrity
  3. What are the differences between Sigrity Engine I and Engine...
  • Subscribers 21
  • Views 8404
What are the differences between Sigrity Engine I and Engine II?
SimTech
SimTech over 4 years ago
The “Set Up Computer Resources” option is available only if you select the Sigrity Engine II license from the Choose Licenses Suite dialog box when launching Layout Workbench or the Sigrity tool. For Example, PowerSI II or OptimizePI II.
It supports the following methods for the simulation:
  • Setting up Resources for a Local Simulation on Windows
    • You can use Distributed Solver Option and specify the total CPUs.
  • Set up Resources for a Local Simulation on Linux
    • You can run a local simulation using any of the following three methods:
      1. Standalone Linux machine
      2. Multiple Linux machines using SSH or RSH
      3. Server Farm
                     Figure 1. Setup Computer Resources window in Windows
                    Figure 2 . Setup Computer Resources window in Linux
Team SimTech
Cadence Design Systems
  • jillashiva
    0 jillashiva over 3 years ago
    Further here are the interesting details on how the distributive computing happens in Power SI solver Click Here
