  2. Sigrity
  3. Convert S-parameter into TDR Waveforms
  • Subscribers 21
  • Views 10583
SimTech
SimTech over 4 years ago
In 2022 Hotfix2 PowerSI/BNPViewer, user can convert S-parameter into TDR waveforms directly:
For each return loss curve, calculate TDR impedance based on the parameter in the TDR setting button:
S parameters showing the Return loss
Now the S parameters are converted to TDR Plots
Team SimTech
Cadence Design Systems
  • SimTech
    SimTech over 3 years ago
    There is an article which explains the above procedure in detail. You can refer to S-Parameter to TDR conversion in PowerSI.
