  2. Sigrity
  3. S parameters in low frequency
  • Subscribers 21
  • Views 8508
Ronic
Ronic over 4 years ago
I simulate the S-parameters of a small PCB (20 x 20 cm), with several ports, using PowerSI Model Extraction.
I'm surprised to notice that in low frequency (f < 1Hz) some S parameters can have a phase different from 0°.
for me, at low frequency, all couplings are dominated by the resistive effect in the dielectric material,
and as the wavelength is huge at f < 1Hz, compare to my board size, I should see all the waves at any port of my PCB with no phase shift.
do I need to use some specific options in PowerSI to get an accurate result at low frequencies ?
I tried to use the PowerDC option with "passivity and causality enforcement" checked.
the results are a bit better as the phases curves are converging on the first simulation point (f ~ 0.01 Hz) to a phase of 0° or 180°... but not all curves converge to 0° !
do I understand something wrong ?
thank you for your help
best regards
ronic
  • jillashiva
    0 jillashiva over 3 years ago
    You can turn on the Enable Port Generation Analysis Flow option when Calculate DC point as reference is selected  I found this option is helpful specially when performing the PDN Analaysis, you can also try option Enable DC accuracy mode and see if it helps.
