  2. Sigrity
  3. Sigrity – Tip of the week: How to include Ferrite Bead model...
  • Subscribers 21
  • Views 7225
Sigrity – Tip of the week: How to include Ferrite Bead model in PowerSI
SimTech
SimTech over 3 years ago
Ferrite beads are used in electronic circuits to suppress high-frequency electronic noise. They are used as a passive low-pass filter by dissipating radio-frequency energy as heat by design. The ferrite creates an inductor with a low Q factor. Ferrite beads do block high frequencies, but only in a specific band.
A design that uses a ferrite bead to improve noise filtering must consider specific circuit characteristics and the frequency range to block. If you have ferrite beads in a design, you can include them in PowerSI by copying and pasting the content of subckt in MOD into Component Manager.
For example, the following image shows a ferrite bead used for EMI suppression.
The ferrite bead can be represented as a SPICE Circuit.
We would like to hear from you how you model ferrite beads in your simulations.
Team SimTech
Cadence Design Systems
  • SimTech
    Take a look at the below link to add a two-pin-two-port S-parameter model of a ferrite bead into AMM:
    How to add a two-pin-two-port S-parameter model of a ferrite bead into AMM
