  2. Sigrity
  3. PDN: Series Resistor
  • Replies 11
  • Subscribers 23
  • Views 11822
Gajendiran
Gajendiran over 3 years ago
I have simulated the power plane in Sigrity Optimize-PI. Actually, The design looks like the below image. In the simulation, I considered two different nets (Vout-1 and Vout-2) and assigned all bulk and de-caps models but did not assign any model for the resistor and simulated and got the below result.
Simulated Results
The question is what impact of the resistor? is it shorted between the two different nets (Vout-1 and 2) or included the actual resistor 3.4 mOhm value in the simulation? Please confirm how it works.
  • Gajendiran
    0 Gajendiran over 3 years ago
    Just following up on the above post. Is there any update on this? I'm waiting for your reply.
    Thank you!
  • Sumith
    0 Sumith over 3 years ago in reply to Gajendiran
    Hi Gajendiran,
    Assuming you put the port on the load and looking at Z parameter graph at DC, the Resistor model is included in the analysis.
    Sumith
  • Gajendiran
    0 Gajendiran over 3 years ago in reply to Sumith
    Hi Sumith,
    Thanks for your reply,
    Yeah, I put the abbreviation point at load but did not assign any model to the resistor. The resistor model will be assigned by default? based on the layout value?
  • ShivaShankarM
    0 ShivaShankarM over 3 years ago in reply to Gajendiran
    Hi Gajendiran,
    Did you check the component manager to see if the model was defined? Do you have a picture of what it looks like?
    A default value will not be assigned by OPI.
    Shiva Shankar M
  • Gajendiran
    0 Gajendiran over 3 years ago in reply to ShivaShankarM
    Hi Shiva,
    Does components manager mean discrete option?
