  2. Sigrity
  3. PDN: Series Resistor
  • Replies 11
  • Subscribers 23
  • Views 11823
Gajendiran
Gajendiran over 3 years ago
I have simulated the power plane in Sigrity Optimize-PI. Actually, The design looks like the below image. In the simulation, I considered two different nets (Vout-1 and Vout-2) and assigned all bulk and de-caps models but did not assign any model for the resistor and simulated and got the below result.
Simulated Results
The question is what impact of the resistor? is it shorted between the two different nets (Vout-1 and 2) or included the actual resistor 3.4 mOhm value in the simulation? Please confirm how it works.
  • mahimag
    0 mahimag over 3 years ago in reply to Gajendiran
    Hi Gajendiran,
    The green check mark shows that the model for the resistor R141 is included in the simulations. Also, the screenshot you have shared is not a component manager, however you can see this from the Discrete(optional) in the workflows. Component Manager can be invoked from Setup > Component Manager.
    Mahima
  • Gajendiran
    0 Gajendiran over 3 years ago in reply to mahimag
    The resistor model will be assigned by default? And resistor value is based on the layout value?
  • geda
    0 geda over 3 years ago in reply to Gajendiran
    The resistor model might have come from the board schematic/layout, which gets translated into OPI.
    OptimizePI will not assign any default models to any component.
    Jeswanth
  • Gajendiran
    0 Gajendiran over 3 years ago in reply to geda
    Hi Jeswanth,
    Thank you for your reply!
    And also, I need to add the VRM model of the regulator, which is not similar to the Sigrity equivalent circuit.
    Sigrity equivalent circuit:
    Regulator:
    Can the above regulator VRM model be added to the optimize PI?
  • Gajendiran
    0 Gajendiran over 3 years ago in reply to Gajendiran
    just following up on the above query. Is it possible to assign a custom VRM model to the regulator in Optimize PI simulation?
