  2. Sigrity
  3. How to get the via backdrill layers through TCL script.
  • Subscribers 21
  • Views 2272
ABIKRISHNA
ABIKRISHNA over 1 year ago
Hello Team,
                 I am currently working on automating a task in PowerSI 2021.1 using a TCL script. My goal is to remove the backdrill from vias based on a given net name. We are able to retrieve the vias associated with the net, but we are unable to get the details of each via connecting layers using script.
Could you please advise on how to identify the backdrill start and end layers of via through TCL.
  • CadAP
    0 CadAP over 1 year ago
    ABIKRISHNA
    Please try the below command it provide via details:
    The result format is:
    {viaName netName|UnnamedNets upperLayerName lowerLayerName upperNodeName lowerNodeName padStackName}.
    set lAllVia [sigrity::query -Via]
    foreach via $lAllVia {
    #puts $via
    sigrity::querydetails via -name $via
  • ABIKRISHNA
    0 ABIKRISHNA over 1 year ago in reply to CadAP
    Hi CadAP,
                Thanks for your suggestion. We already used this query to get the layer details of the vias. However, we still need a method to identify only the via backdrill layers.
    We would like to explain our scenario clearly:
    For example, consider a through-via in a 32-layer PCB. If the via is used only up to Layer 7 from the Top side, then the portion from Layer 8 to Layer 32 becomes a stub. This section requires backdrilling.
    We are looking for a TCL-based method or any PowerSI option that can provide the start layer and end layer of the via stub for each via instance.
    Although we can extract general via layer information through the existing queries, it does not help us identify the exact backdrill layers in different topologies. The stub portion is not directly distinguishable from the current output.
