  2. Sigrity
  3. Why does DDR5 technology require IBIS-AMI models, whereas...
  • State Verified Answer
  • Subscribers 20
  • Views 443
Why does DDR5 technology require IBIS-AMI models, whereas traditional IBIS or SPICE-only simulations were often sufficient for earlier DDR generations?
Sumith
Sumith 27 days ago
Options:
A. DDR5 operates at lower voltages and therefore requires larger S-parameter files.
B. DDR5 introduces receiver and transmitter equalization techniques such as DFE, CTLE, and FFE, which cannot be accurately represented using traditional IBIS models alone.
C. DDR5 replaces all channel simulations with transistor-level SPICE simulations.
D. DDR5 eliminates the need for signal integrity analysis by using on-die termination.
  • StephenNewberry
    StephenNewberry 27 days ago +1 verified
    B :)
  • StephenNewberry
    +1 StephenNewberry 27 days ago
    B :)
  • Sumith
    0 Sumith 16 days ago in reply to StephenNewberry
    Hi Stephen, curious about your experience with DDR5 designs and topology analysis. Any interesting challenges, approaches, or learnings you could share with the community?
  • StephenNewberry
    0 StephenNewberry 14 days ago in reply to Sumith
    The big challenge is that many of the simulation tools originally were not configured to run parallel interfaces with AMI models and the required equalization. By now most of the tools have the ability to support these parallel interfaces with non-ideal clocking. The new function was originally known as GetWave2 - here's a reference from some years ago:
    https://www.signalintegrityjournal.com/articles/2020-back-to-basics-ibisibis-ami-and-the-path-to-lpddr5
    I've also done a couple of webinars in partnership with Cadence/EMA about using Topology Xplorer for DDR5:
    https://shielddigitaldesign.com/posts/2022/ema-webinar-dive-ddr5/
    https://shielddigitaldesign.com/posts/2022/ema-webinar-ddr5-analysis/
