This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
Writing PSpice Flat Netlist C:\PSD_Data\Power Supply-PSpiceFiles\SCHEMATIC1\SCHEMATIC1.net WARNING [NET0093] No PSpiceTemplate for U1, ignoring/* PSpice netlist generation complete
I tried in so many ways to make it work, but nothing. Can anyone tell me what I'm doing wrong? Thanks Juan Manuel Ibañez
Hi!
Maybe you're using a non-Pspice library.
Those libraris don't have the data necessary to run PSpice.
Use the ones who have those info. They're located underneath the rest of the Capture libraries.
Yes!
Otherwise, a lot of electronic components manufacturers have their own generated Pspice models to use in your own simulations.
You're welcome ^^
I'm also having difficulty when I try to run a simulation from capture. When I run a simple circuit with resisters I get a reasonable output in biasis point with a DC Voltage. When I substitute an AC source in the circuit for the DC source I get zeros through out the circuit for both node voltages and branch currents.
