• Home
  • Community
  • Forums
  • Feedback, Suggestions, and Questions
  • Single Sign On Error
Forums
Started by debaabed on 16 Jul 2020 6:51 PM. Topic has 2 replies and 2692 views.
Last post on 19 Jul 2020 9:49 AM by debaabed.
Hi
I am trying to login to Cadence Learning Management System(LMS) but I get SSO Error as shown below.
 Single-Sign-On Error
An attempt to authenticate using Single-Sign-On has failed. Please contact your network administrator to resolve this malfunction.
I have a valid id and can access support.cadence.com and community.cadence.com. So not sure why this error happens?
Please look into this.
Regards
DB
debaabed
debaabed
  • 16 Jul 2020 6:51 PM
  • Reply
    Andrew Beckett
    • 16 Jul 2020 11:31 PM
    Dear DB,
    This is a forum for questions, suggestions and feedback about the community forums. It is not for support nor for help with the learning management system. Nobody responsible for the LMS will be here, and I mainly follow this specific forum because 99% of the posts in this forum should be elsewhere so I redirect them.
    For login issues, please follow the suggestion on the login page for lms:
    Kind Regards,
    • Reply
  • debaabed
    debaabed
    • 19 Jul 2020 9:49 AM
    In reply to Andrew Beckett:
    Hi Andrew
    Thanks. I was also not sure about whether this is the right forum for such kind of things.
    I will contact at the required link.
    • Reply
