  3. Virtuoso 6.1.5 warnings issues
  • Replies 8
  • Subscribers 129
  • Views 19154
djamal
djamal over 11 years ago
I need some help if possible on the following issue:
*WARNING* (reader): string at line 1 was not terminated on EOF, '"' added at line 2 of string "...)"
I made a lot of search on google unfortunately without success.
Thank you in advance.
Note: The complete Log is given below.
Program:        @(#)$CDS: virtuoso version 6.1.5 09/07/2011 12:14 (sfsol608) $
Sub version:        sub-version  IC6.1.5.500.6  (32-bit addresses)
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading pvsskill.cxt.
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
*WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added
                    at line 2 of string "...)""
*WARNING* (reader): illegal character '$' ignored at line 1 of string "...                        $"
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.11s.
Loading NCSU CDK 1.5.1 customizations...
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool adle
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool asimenv
*WARNING* envSetVal: Can't set the value of variable 'width',
    in tool[.partition] 'asimenv.plotting' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'height',
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool ddserv
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool layout
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool schematic
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool ui
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool asimenv
Loading NCSU SKILL routines...
Done loading NCSU_CDK customizations.
  • djamal
    Using "virtuoso -nocdsinit" didn't resolve the problem. Below is the output generated in the CIW.
    COPYRIGHT © 1992-2011  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
              © 1992-2011  UNIX SYSTEMS Laboratories INC.,
                             Reproduced with permission.
    This Cadence Design Systems program and online documentation are
    proprietary/confidential information and may be disclosed/used only
    as authorized in a license agreement controlling such use and disclosure.
              RESTRICTED RIGHTS NOTICE (SHORT FORM)
    Use/reproduction/disclosure is subject to restriction
    set forth at FAR 1252.227-19 or its equivalent.
    Loading geView.cxt
    Loading schView.cxt
    Loading LVS.cxt
    Loading xlUI.cxt
    Loading auCore.cxt
    Loading vhdl.cxt
    Loading seismic.cxt
    Loading ci.cxt
    Loading ams.cxt
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.10s.
  • djamal
    Loading geView.cxt
    Loading schView.cxt
    Loading LVS.cxt
    Loading xlUI.cxt
    Loading auCore.cxt
    Loading vhdl.cxt
    Loading seismic.cxt
    Loading ci.cxt
    Loading ams.cxt
