  3. How to use PSS+PSTB or PSS+PAC to simulation the loop gain...
  • Replies 20
  • Subscribers 133
  • Views 32564
How to use PSS+PSTB or PSS+PAC to simulation the loop gain of the amplifier in the MDAC in each clock phases
ringamplifier
ringamplifier over 9 years ago
Hello, everyone!
I am currently designing  a amplifier for the multiplying dac (MDAC) for the pipeline ADC. The circuit diagram is show in Fig. 1. This circuit operates  in two clock phases: phi1 and phi2. In phi1, the amplifier is auto-zeroing and its offset will be sampled in capacitor Cc. Vin is sampled in C1 and C2. In phi2, the amplifier will do the amplification. Clearly, the feedback factor of the amplifier in phi1 and phi2 is different. So I want to simulation the loop gain in phi1 and phi2 separately and also want to see the effect of different feedback factors.
Since this circuit is a discrete time circuit, it seems that I should use PSS analysis to find its operation point and do the small signal analysis to analysis the loop gain.
I also found a slide in the internet to teach how to use the PSS+PSTB simulation to analysis the loop gain of switched capacitor CMFB. The link is
lumerink.com/.../Loop%20Stability%20Analysis.pdf
However, I have a question about the method using in this slide. For better description, pls see Fig. 2 (actually page 28 of the slide). The SC CMFB also operates in two clock phases. The feedback capacitor of the CMFB circuit is different is each phase. So the question is how can the PSS analysis distinguish two clock phases and PSTB simulation results is corresponding to which clock phase?
So I want to make a clear statement of my question:
How to use PSS+PSTB or PSS+PAC to simulation the loop gain in each clock phase
Fig. 1
Fig. 2
  • MikeHarris
    MikeHarris over 8 years ago
    Unknown said:
    Hello Christian,
    That problem is still unsolved. I agree with you that PSTB averages the loop gain during two phases. But as I have more works in the chopper amplifier, I think that the PSS+PSTB analysis may not suitable to measure the loop gain within a single phase. Because PHI1 and PHI2 are total two different phases. It's not like the case in chopping: chopping works in two clock phases but still the same loop same circuit. That's why you can find some articles talk about the PSS+PSTB method to simulate the loop gain of a DC-DC converter but seldom in Switched Capacitor (SC) circuit. For SC circuit, I only see the PSS+PSTB method in simulating the loop gain of SC common mode feedback (CMFB) circuit. Although SC-CMFB circuit is actually different in two clock phases (because the value of feedback capacitor is different), they are approximately the same loop and same circuit.
    So If we really want to simulate the loop gain of the amplifier in the SC feedback. I think we can do something like what we do in SC-CMFB. But I did't try it before.
    Yan
    Interestingly I have the exact same problem. My circuit auto zeros on phase 1 and amplifies on phase 2. When I run a pstb sim using either the diffstbprobe probe or the cmdmprobe (I put it only in the autozero path since that's the worst case for stability)  I get an open loop gain less than 1 and it reports that the loop is unstable. I have compensated it by optimizing the step response so I know its probably got a phase margin around 60 degrees and a gain margin probably over 15dB but I haven't found a way to actually measure it. One problem I have is I'm using a switched capacitor feedback loop so I have to run for a few cycles to get it to stabilize so I can't run an ac type stability analysis. I've tried stripping out the common mode loop and replacing it with an ideal CMFB structure but that results don't make sense either. I suspect there is some interaction between the differential and common mode loops.
    Andrew, you mentioned something about a way to run an AC analysis around a bias point set by a transient sim. Is that correct? If so, can you describe this method. Thanks for your help!
  • MikeHarris
    Unknown said:
    Hello Christian,
    Yan
