  3. How to use PSS+PSTB or PSS+PAC to simulation the loop gain...
  • Replies 20
  • Subscribers 137
  • Views 38525
How to use PSS+PSTB or PSS+PAC to simulation the loop gain of the amplifier in the MDAC in each clock phases
ringamplifier
ringamplifier over 10 years ago
Hello, everyone!
I am currently designing  a amplifier for the multiplying dac (MDAC) for the pipeline ADC. The circuit diagram is show in Fig. 1. This circuit operates  in two clock phases: phi1 and phi2. In phi1, the amplifier is auto-zeroing and its offset will be sampled in capacitor Cc. Vin is sampled in C1 and C2. In phi2, the amplifier will do the amplification. Clearly, the feedback factor of the amplifier in phi1 and phi2 is different. So I want to simulation the loop gain in phi1 and phi2 separately and also want to see the effect of different feedback factors.
Since this circuit is a discrete time circuit, it seems that I should use PSS analysis to find its operation point and do the small signal analysis to analysis the loop gain.
I also found a slide in the internet to teach how to use the PSS+PSTB simulation to analysis the loop gain of switched capacitor CMFB. The link is
lumerink.com/.../Loop%20Stability%20Analysis.pdf
However, I have a question about the method using in this slide. For better description, pls see Fig. 2 (actually page 28 of the slide). The SC CMFB also operates in two clock phases. The feedback capacitor of the CMFB circuit is different is each phase. So the question is how can the PSS analysis distinguish two clock phases and PSTB simulation results is corresponding to which clock phase?
So I want to make a clear statement of my question:
How to use PSS+PSTB or PSS+PAC to simulation the loop gain in each clock phase
Fig. 1
Fig. 2
    The Periodic Stability analysis (pstb) does not give you the loop gain in each phase. It gives you the time-averaged loop gain over the whole period, which is what you really want. If you want the loop gain in a particular phase, you could run a transient, set up a stb analysis, and then specify the acnames and actimes parameters of the tran analysis to measure the loop gain at the times where each loop is closed. However, that is probably not what you want... pstb is more likely to be useful.
    Similarly, Periodic AC (pac) gives you the time-averaged small-signal response to a small signal input over the period.
    A couple of corrections from the document you referenced (there may be others, I just scanned it quickly):
    • The iprobe does not "break" the loop. The loop remains closed at all times, which is the point of these analyses. It is the perturbation/measurement point for the loop gain
    • You should no longer use cmdmprobe to measure differential and common-mode stability. Instead there is a superior component, diffstbprobe which copes with the loops not being balanced (i.e. if there is common-mode to differential-mode leakage or vice versa) and also allows the choice of whether you are measuring common mode or differential mode to be made on the analysis form, rather than on the component itself.
  • ringamplifier
    Hello!
    Andrew,
    Thanks for your professional reply!
    Now for my understanding, the Switched Capacitor Common Mode Feedback Cicuit (SC-CMFB), although operating in two different clock phases (the total capacitor connected in the loop is different in each phase), it makes the output common mode voltage to "jump" up and down around the desired value, to mimic the continues time one. The two different clock phases are relative to each other. So I think the "the time-averaged loop gain over the whole period" provided by Periodic Stability  analysis (pstb) is reasonable if we want to use pstb to assess the loop stability of the SC-CMFB.
    But for the Multiplying DAC (MDAC)  circuit I referred in Fig. 1, it operates in two different clock phases and each phase has different function (phi1 is auto-zeroing, feedback factor is nearly one; phi2 is amplification, feedback factor is determined by C1/(C1+C2) ) . These two phases are not "coherent" like that of SC-CMFB.  In order to make sure this circuit is stable, I need to make sure this circuit is stable in each phase. So that's why I want to find some method to assess the stability of particular phase.
    However, the amplifier I used in the MDAC is a highly non-linear amplifier. So It's hard for me to specify a time to "represent" the amplifier in the transient simulation then use the method that you referred. So I want to use the pstb to analysis  "the time-averaged loop gain" within a particular phase.
    But as you said "The Periodic Stability analysis (pstb) does not give you the loop gain in each phase ", pstb may be not OK for this purpose.
    I really want your comments and suggestions !
    Best,
    Shen
    Hi Shen,
    OK - I'd not looked at the small diagram with the two phases indicated. You have two feedback loops - each switched by a different phase. You need to insert the iprobe (or diffstbprobe if it's differential - your Fig 1 only shows a single-ended amplifier) in the loop you're interested (you can have both components there and just pick the one you want when simulating). If the probe is at the output of the amplifier it would include the effects of both loops; if it was in just the loop for phase 1 or phase 2, it would include just that feedback path.
    You definitely don't want to use acnames/actimes with tran analysis for this (I said that was unlikely to be what you want).
  • ringamplifier
    Hello Andrew,
    That's mean If the probe was just in the loop for phase 1(for example), the pstb analysis will give me the "time-averaged loop gain"  just within this phase 1. Am I right?
    Now I just the simulation by inserting the iprobe (now I am just using a single-ended amplifier made of VCCS, resistor. 80 dB DC gain) into the auto-zeroing loop (phi1 in Fig. 1). Then run the PSS+PSTB analysis. The location of the iprobe is shown as a red box in Fig. 3. After I plot the magnitude of the loop gain (in the "Direct Plot Form"), I found that it didn't give me the expected value (80dB) but a gain of  22.26dB. I was wonder what's wrong about ti.
    Fig. 3
    Best,
    shen
    What do the clock phases look like (from the PSS time domain results)? Can post a plot?
    Note that you're still looking at the time-averaged loop gain over the whole period, not just when that switch is enabled. I'm afraid I don't have enough bandwidth this week to put together a similar example to try it out (I have the day job to do...)
  • ringamplifier
    Hello Andrew,
    these pictures show my test bench and simulation results:
    Schematic : the opamp made of  VCCS (1 mS), resistor (1M Ohm), capacitor (1f P), with gain of 80dB, all the other capacitors are equal to 200f
    PSS and PSTB setting
    PSS time domain result:
    PSTB result
    Can you please post the input.scs file?
  • ringamplifier
    Hello !
    This is the input.scs file
    simulator lang=spectre
    global 0
    include "/home/yanrongshen/cdslocallib/artist/ahdlLib/quantity.spectre"
    include "models.scs"
    parameters a=25m Waz2=6 Waz1=6 Waz=8 Wout=2 Win=16 Wcm=2 Cload=.4p \
        cstable=0.8p Vcm=0.6 T=20n Vin=0m power=1.2 Cs=200f Cf=200f \
        pre=power/2.0
    // Library name: ringamp2016
    // Cell name: ringamp2nd
    // View name: schematic
    I13 (net060 net053 net054) nand_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
            tdel=10p trise=30p tfall=30p
    I2 (net055 clk_master net057) nand_gate vlogic_high=1 vlogic_low=0 \
            vtrans=0.5 tdel=10p trise=30p tfall=30p
    I3 (clk_master clk_master net060) nor_gate vlogic_high=1 vlogic_low=0 \
    I12 (net055 net055 net494) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
    I11 (net069 net069 net055) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
    I10 (net054 net054 net069) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
            tdel=250p trise=30p tfall=30p
    I86 (net053 net053 net475) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
    I85 (net078 net078 net053) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
    I9 (net057 net057 net078) nor_gate vlogic_high=1 vlogic_low=0 vtrans=0.5 \
            tdel=50p trise=30p tfall=30p
    IPRB0 (net090 net277) iprobe
    C16 (net359 net090) capacitor c=200.0f
    C18 (net502 AGND) capacitor c=1.000f
    C15 (net419 VCM) capacitor c=Cload
    C13 (net411 net359) capacitor c=Cs
    C14 (net359 net395) capacitor c=Cf
    R6 (net502 AGND) resistor r=10M
    W21 (VCM net359 Phase2e 0) relay vt1=power/2-1m vt2=power/2+1m ropen=100G \
            rclosed=10.0
    W28 (net419 net375 Phase2 0) relay vt1=power/2-1m vt2=power/2+1m \
            ropen=100G rclosed=10.0
    W24 (net457 net395 Phase2 0) relay vt1=power/2-1m vt2=power/2+1m \
    W25 (net395 net502 Phase1 0) relay vt1=power/2-1m vt2=power/2+1m \
    W27 (net457 net411 Phase2 0) relay vt1=power/2-1m vt2=power/2+1m \
    W20 (net502 net419 Phase1 0) relay vt1=power/2-1m vt2=power/2+1m \
    W23 (net277 net502 Phase2 0) relay vt1=power/2-1m vt2=power/2+1m \
    W22 (net411 VCM Phase1 0) relay vt1=power/2-1m vt2=power/2+1m ropen=100G \
            rclosed=10.0
    V3 (VCM AGND) vsource dc=600.0m type=dc
    V0 (AGND 0) vsource type=dc
    V1 (AVDD AGND) vsource dc=1.2 type=dc
    V5 (DVDD 0) vsource type=dc
    V15 (net375 0) vsource dc=pre type=dc
    V16 (net457 VCM) vsource dc=Vin type=dc
    I54 (net470 net486 net465) or_gate vlogic_high=1.2 vlogic_low=0 vtrans=0.6 \
            tdel=20p trise=20p tfall=20p
    I53 (net486 net470 Phase2e) and_gate vlogic_high=1.2 vlogic_low=0 \
            vtrans=0.6 tdel=20p trise=20p tfall=20p
    I2289 (net469 net470) not_gate vlogic_high=power vlogic_low=0 \
            vtrans=power/2 tdel=0 trise=20p tfall=20p
    I57 (Phase2e inv_Phase2e) not_gate vlogic_high=power vlogic_low=0 \
            vtrans=power/2 tdel=20p trise=20p tfall=20p
    I2291 (net475 net469) not_gate vlogic_high=power vlogic_low=0 \
    I2287 (net494 net483) not_gate vlogic_high=power vlogic_low=0 \
    I58 (Phase2 inv_Phase2) not_gate vlogic_high=power vlogic_low=0 \
    I55 (net465 net480) not_gate vlogic_high=power vlogic_low=0 vtrans=power/2 \
    I56 (net480 Phase2) not_gate vlogic_high=power vlogic_low=0 vtrans=power/2 \
    I2292 (net483 Phase1) not_gate vlogic_high=power vlogic_low=0 \
    I7 (net488 net486) not_gate vlogic_high=power vlogic_low=0 vtrans=power/2 \
    I2293 (net470 net488) not_gate vlogic_high=power vlogic_low=0 \
    I2288 (Phase1 inv_Phase1) not_gate vlogic_high=power vlogic_low=0 \
    V4 (clk_master 0) vsource type=pulse val0=0 val1=1 period=T rise=30p \
            fall=30p width=T/2.0
    G3 (net502 VCM net090 VCM) vccs gm=1m
    simulatorOptions options reltol=1e-4 vabstol=1e-9 iabstol=1e-15 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        dochecklimit=yes checklimitdest=psf
    dcOpCheckLimit checklimit checkallasserts=yes severity=none
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    pss  pss  fund=50M  harms=0  errpreset=moderate  tstab=500n
    +    cmin=10a  method=gear2only  tstabmethod=gear2only  maxacfreq=1G
    +    annotate=status
    pstb pstb start=1 stop=1G dec=100 probe=IPRB0 annotate=status
    subckts info what=subckts  where=rawfile
    asserts info what=assert  where=rawfile
    saveOptions options save=allpub subcktprobelvl=2
    ahdl_include "/home/yanrongshen/cdslocallib/artist/ahdlLib/nand_gate/veriloga/veriloga.va"
    ahdl_include "/home/yanrongshen/cdslocallib/artist/ahdlLib/nor_gate/veriloga/veriloga.va"
    ahdl_include "/home/yanrongshen/cdslocallib/artist/ahdlLib/or_gate/veriloga/veriloga.va"
    ahdl_include "/home/yanrongshen/cdslocallib/artist/ahdlLib/and_gate/veriloga/veriloga.va"
    ahdl_include "/home/yanrongshen/cdslocallib/artist/ahdlLib/not_gate/veriloga/veriloga.va"
  • ChrisAnalogue
    ChrisAnalogue over 9 years ago
    Hello Andrew, Yan,
    I have exactly the same problem.
    PHI1= Auto-Zero with unit gain configuration
    PHI2= Amplification phase (different feedback factor)
    My understanding problem is following:
    PSTB averages the loopgain of the IPROBE (see fig. above red rectangle) during e.g PHI1 & PHI2.
    However during PHI2 the loop form IPROBE is completely open. So during PHI2 a correct loopgain (LG) result cannot be obtained & therefor the average LG cannot be correct, right?
    Is there a procedure known how to solve that problem?
    Kr Christian
  • ChrisAnalogue
    Hello Andrew, Yan,
    Kr Christian
