  3. How to use PSS+PSTB or PSS+PAC to simulation the loop gain...
  • Replies 20
  • Subscribers 133
  • Views 32586
How to use PSS+PSTB or PSS+PAC to simulation the loop gain of the amplifier in the MDAC in each clock phases
ringamplifier
ringamplifier over 9 years ago
Hello, everyone!
I am currently designing  a amplifier for the multiplying dac (MDAC) for the pipeline ADC. The circuit diagram is show in Fig. 1. This circuit operates  in two clock phases: phi1 and phi2. In phi1, the amplifier is auto-zeroing and its offset will be sampled in capacitor Cc. Vin is sampled in C1 and C2. In phi2, the amplifier will do the amplification. Clearly, the feedback factor of the amplifier in phi1 and phi2 is different. So I want to simulation the loop gain in phi1 and phi2 separately and also want to see the effect of different feedback factors.
Since this circuit is a discrete time circuit, it seems that I should use PSS analysis to find its operation point and do the small signal analysis to analysis the loop gain.
I also found a slide in the internet to teach how to use the PSS+PSTB simulation to analysis the loop gain of switched capacitor CMFB. The link is
lumerink.com/.../Loop%20Stability%20Analysis.pdf
However, I have a question about the method using in this slide. For better description, pls see Fig. 2 (actually page 28 of the slide). The SC CMFB also operates in two clock phases. The feedback capacitor of the CMFB circuit is different is each phase. So the question is how can the PSS analysis distinguish two clock phases and PSTB simulation results is corresponding to which clock phase?
So I want to make a clear statement of my question:
How to use PSS+PSTB or PSS+PAC to simulation the loop gain in each clock phase
Fig. 1
Fig. 2
    Because I have no visibility of your circuit - it might be OK, or it might not. If there is a point in the period where the loop is closed, then it could be useful - but I didn't know that for certain because I haven't seen your circuit. That said, I would still expect the time-averaged loop gain to be more useful as a metric, but as I said, a better answer could be given by somebody who can see the topology of your circuit.
    Enjoy your vacation!
  • nraf
    nraf over 4 years ago in reply to Andrew Beckett
    Hi Andrew or Mike - was there any closure on this issue? I have a "simple" amp with an AZ (unity gain) phase and then a capacitive feedback phase (gain=Cin/Cf) - does the transient/stb method work for independent phases?
    thanks, Neil.
    Andrew Beckett over 4 years ago in reply to nraf
    Neil,
    I can't answer your question - since I don't know what happened after my last append. I already explained why doing this with a switching feedback circuit may not make sense (i.e. looking at the loop gain at an instantaneous bias point if there is no feedback loop at that time).
  • nraf
    For the record, running an stb analysis at transient bias points based towards the end of each phase *seems* to give me sensible results....however, as you have pointed out above, this gives an instantaneous loop gain and not 'time-averaged'. (Also, as stated above, the auto-zero AZ path is giving wc results for PM, the probe is on the output of the amp).
    Neil.
  • nraf
    Neil.
