  3. Purging duplicate vias in pcb editor
  • Views 13914
Micheal schenk
Micheal schenk over 4 years ago
How do we purge/remove the duplicated vias in the same location of the PCB editor? These vias are not the one stacked and they are just blind vias running in internal layers 12-14. I find there is an additional copy of the blind via at the same location. Not sure what caused this issue.
  • steve
    steve over 4 years ago
    A Database Check may/may not remove these but worth a try. If not turn on the duplicate drill holes DRC (Setup - Constraints -  Modes then General) which will show a DRC where they are.
  • RFinley
    RFinley over 4 years ago
    This happens all the time to people who translate to Allegro to delay confronting management over the inevitable:  floating PADS out to the middle of a pond and setting fire to it.
    https://community.cadence.com/cadence_technology_forums/f/pcb-skill/13232/any-way-to-identify-double-hits-via
