  3. Noise summary data per sub-block in Maestro output expr...
  • Subscribers 129
  • Views 3370
Noise summary data per sub-block in Maestro output expressions
DKaraca
DKaraca over 1 year ago
I have a question about printing noise summary via maestro output expressions.
How can I print noise data using output expressions, for multiple levels of the hierarchy?
I have found this article which describe the procedure using ocnGenNoiseSummary() function: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000007MViHEAW&pageName=ArticleContent
I see also Andrew Beckett referring to the above mentioned article as a solution to a similar question: community.cadence.com/.../noise-summary-per-instance
However, this seems to work only if I'm to extract noise data from a single level of hierarchy.
If I have the output expression "ocnGenNoiseSummary(2 ?result 'hbnoise)", it will generate a "noisesummary" directory under results directory for a hierarchy level of 2.
If I am to extract data from various hierarchy levels, I should be able to generate multiple noise summary directories, such as noisesummary1, noisesummary2 where they correspond to "ocnGenNoiseSummary(1 ?result 'hbnoise)" & "ocnGenNoiseSummary(2 ?result 'hbnoise)", respectively. However this does not seem to be possible.
Can you please advice? Thanks.
My Cadence version: IC23.1-64b.ISR7.27
BR,
Denizhan Karaca
