  3. Netlisting error when doing parametric sweep on transient...
  • Subscribers 131
  • Views 4494
Netlisting error when doing parametric sweep on transient simulation
Volker T
Volker T over 1 year ago
Dear all,
I defined two design variables in ADE Assembler, say V1 and V2, that define the voltage 1 and voltage 2 of a "vpulse" voltage source in my schematic.
Then, I define V1 = 1.0, and V2 = 2.0, run a transient simulation, and everything is as expexcted. The source provides pulses between 1.0 V and 2.0 V.
Next, I set V1 = 1.0:0.5:1.5, thereby creating a parametric sweep with 1.0 V and 1.5 V for V1. I keep V2 at 2.0 V. Then the simulation fails, and all I get is "netl err" in my Output Expressions and an error message that the results directory does not exist and nothing can be plotted: This is reasonable, as the results directory is deleted on starting a new simulation, and as there is no simulation result, none of my output expressions can be plotted.
WARNING (OCN-6040): The specified directory does not exist, or the directory does not contain valid PSF results.
        Ensure that the path to the directory is correct and the directory has a logFile and PSF result files.
WARNING (ADE-1065): No simulation results are available.
ERROR (WIA-1175): Cannot plot waveform signals because no waveform data is available for plotting.
One of the possible reasons can be that 'Save' check box for these signals are not selected in the Outputs Setup pane. Ensure that these check boxes are selected before you run the simulation.
Normally, this kind of para,metric sweep is not a problem, I have done this many times before. There must be something special in THIS PARTICULAR test bench or simulator setup. The trouble is, I don't get any useful error messages.
Does anyone know what might be the problem here OR where to find useful information to investigate further (log files stored somewhere)? Thank you!
Volker
P.S. Using Corners instead does not help either. Running it through all values by hand works, though.
  • Volker T
    Solved. I simply ran out of storage space. Unfortunately, there were no messages pointing me to this issue.
