  3. How can I place stacked vias with the size exact same cut...
  • Subscribers 129
  • Views 3740
How can I place stacked vias with the size exact same cut width without metals around?
TzuYun Chang
TzuYun Chang over 1 year ago
As the red part only in the image below?
  • RobMan
    RobMan over 1 year ago
    Use Editor Options to set the 'Create Via" calculation mode...
    'Min Rules' should achieve closest to what you request. However, the via will not violate foundry Constraint Group rules. i.e. It will not create something illegal. So if DRC has min enclosure (And it's defined in the techfile) this will be applied.
    Create->Wire 'Via Configuration' might be setup differently (constraint group or overrides).
  • TzuYun Chang
    TzuYun Chang over 1 year ago in reply to RobMan
    I don't know where to find the "Via Parameters Calculation Mode". I am using IC23.1 and when I go to "Create" > "Via" > "Mode: Stack" > "Options", I can't see anything related to Via Parameters Calculation Mode in the popped up "Create Via Options" window... nor on the window for creating the stacked via.
