  3. Copy cline to solder mask layer
  • State Verified Answer
  • Answers 1
  • Subscribers 163
  • Views 5410
Fredda
Fredda over 1 year ago
I want to make an opening in the solder mask right above a trace that is acting like a guard ring. Do I really need to go and buy the Allegro Productivity Toolbox add-on for using the Cross-Copy tool for a basic operation like that??
/F
  • steve
    +1 steve over 1 year ago
    There is a new command in 24.1 under the Shape menu called Void Adjacent Layer Shapes that should be able to do what you want available in all license levels.
  • excellon1
    +1 excellon1 over 1 year ago
    As Steve suggested the new shape feature to handle this works well so if you are on the latest release you can try that out.
    Other methods do exist if not on latest.
    You could simply draw in the soldermask on the soldermask class to create that mask removal area over your trace using a line. Add the line on the Board Geometry > SolderMask_Top or SolderMask_Bottom.
    There is also an excellent skill utility called cline to shape that can convert your cline to a shape. You can use this shape as your mask removal area by coping it to the
    For best results, Just copy your cline off the board to a free area so as to create the shape as a starting point.
    Best Regards.
  • Fredda
    0 Fredda over 1 year ago in reply to steve
    Thanks. Great, I'll try that the next time! I ended up drawing a shape instead of a cline for the guard ring. And a shape is easy to copy to any layer.
    /F
  • Fredda
    0 Fredda over 1 year ago in reply to excellon1
    Thanks for adding more suggestions for how to solve this!
  • RohitRohan
    0 RohitRohan 8 months ago in reply to steve
    Hi Steve,
    Hope you're doing well!
    Could you please share the steps to create a soldermask opening above the traces using the "Void Adjacent Layer Shapes" option in version 24.1? I’m trying to apply it in my design and would really appreciate your guidance.
    Thanks in advance Slight smile!
    Best regards,
    Rohit Rohan
