  3. Force virtuoso (Layout XL) to NOT create warning markers...
  • Subscribers 129
  • Views 4917
Force virtuoso (Layout XL) to NOT create warning markers in design
CSCNalu
CSCNalu over 1 year ago
Hi
I have a rather strange question - is there a way to tell layout XL to NOT place the error/warning markers on a design when I open a cell?  I do a lot of my layout by using arrays from placed instances and create mosaics that completely ignore the metadata that Layout XL uses with its bindings with schematic (and instances get deleted etc. but I do like using it to generate all my pins etc.) and it's just really annoying when I open a design that I know is LVS clean and since the connectivity metadata is all screwed up (because I did not use it to actually complete the layout) I have a design that's just blinking at me at every gate, source and drain.  I typically delete them at the high level heirarchically but the second I go in and modify something and come back up it places all of them again.  I know that if I flatten all the p cells it goes away but sometimes it's nice to have that piece of metadata but that's about it.  Is there a way to "break" the features of XL like this?  I realize what a weird question this is but it's becoming more of an issue since we moved to IC 23 from IC 6 where there is no longer a layout L that I can use free from these annoyances that can't use any of the connectivity metadata.
Chris
  • RobMan
    RobMan over 1 year ago
    First; to comment on your description. Virtuoso Layout XL has never supported binding of mosaics to schematic instances which have differing connectivity. It's not really a case "ignoring" this information. It is not supported. My initial recommendation would be to use structures which are supported in this scenario such as Modgens or Group Arrays.
    With regard to the markers:
    Typically markers are generated when you run 'Check Against Source'. If you do not wish to see markers then avoid this action.
    A difference is in 23.1: There is an option to enable incremental 'Check Against Source'. This will run after every edit. Immediately adding markers for XL non-compliance. It is 'nil' by default. However if it is enabled in your environment...
        envSetVal("layoutXL" "incrementalCas" 'boolean t)
    An alternative is to disable the connectivity source.
      Connectivity -> Update -> Connectivity Reference...
    Disable the schematic view. However, there are many advantages to connectivity driven layout. I would refer to my recommendation to follow the supported methodologies.
    Also, if you have markers you wish to remove this can be done from the Annotation Browser or Verify -> Markers -> Delete/Delete All
  • RobMan
    RobMan over 1 year ago in reply to RobMan
    Correction..
        envSetVal("layoutXL" "incrementalCas" 'boolean nil)
    to disable incremental check against source.
