  3. Knowledge Booster Training Bytes - Enhance Layout Productivity…
rbaby
rbaby
concurrent layout editing
Knowledge Booster
CLE
ICADVM20.1
Knowledge Booster Training Bytes - Enhance Layout Productivity with Virtuoso CLE
7 Dec 2022 • 6 minute read
 Knowledge Booster
Are you using the sequential Virtuoso Layout flow?
Have you ever wished to perform multiple layout designing and editing tasks in parallel so that more work can be done in given time?
If your answer is yes, Virtuoso Concurrent Layout (CLE with E for editing) might be the solution for you. Use it to create multiple partitions in the design and have designers work in parallel, which helps save time and enhances your layout productivity!
In this Knowledge Booster blog, let’s talk about and explore how to do layout design tasks using concurrent editing. The blog:
  • Introduces the training materials and videos that can help you understand and use this feature
  • Shows how to earn a digital badge by passing an exam for the course
The Sequential Virtuoso Layout Flow and Parallel Concurrent Layout Flow
What Is Concurrent Layout Editing?
Virtuoso Concurrent Layout Editor is a layout editing environment that enables designers to work concurrently on the same cellview within the Virtuoso environment. As the designers work in parallel, using concurrent layout helps in bringing down the designing time and, as a result, increases productivity. You can perform concurrent editing in Virtuoso Layout Suite XL combined with 4 GXL flexible license tokens and Virtuoso Layout Suite EXL.
 What Is the Concurrent Layout Editing?
1. Initialize the Top Design for Concurrent Layout Editing: The first task for the manager is to initialize the design to get it ready for concurrent editing.
 Initializing the Top Design for Concurrent Layout Editing
2. Define the Design Partitions: After the design is initialized, you can start defining the area-based/layer-based design partitions based on your editing requirements.
 Defining an Area-Based Design Partition
3. Edit the Design Partitions: After the required design partitions and design partition views are created, designers can start editing the allocated design partition views.
 Editing the Design Partition userA Hierarchically Using the CLE Flow
4. Import the Peer Design Partitions: You can import the changes made in the peer design partitions and view the updated design.
 Importing/Unimporting the Peer Design Partition Updates After Concurrent Layout Editing
5. Merge the Top Design: After the designers have completed editing the design and submitted their respective design partitions for merge, the manager needs to review these requests and then either approve or reject the merge requests.
Merging the Submitted Design Partitions userA and userB
The manager needs to commit the changes in CLE to complete the merge process and save the merged changes into the top design. After all the design partitions are merged with the top design, the manager can delete and clear all the design partitions and exit the Concurrent Layout Editing environment.
What’s Next?
  • Take the free Virtuoso Layout Pro: T8 Virtuoso Concurrent Layout Editing online course
  • On the Cadence Learning and Support portal (login required) you can view the Virtuoso Concurrent Layout Editing Training Byte Channel Videos:
    • Setting Up the Concurrent Layout Editing Environment
    • Initializing and Partitioning the Top Design in Manager Mode
    • Editing the Design Partition userA in Designer Mode
    • Editing the Design Partition userB in Designer Mode
    • Merging/Committing the Top Design in Manager Mode
    • Quiz on Virtuoso Concurrent Layout Editing
  • And earn a Digital Badge by passing an exam for the course.
Information and FAQs
To find information on how to get an account on the Cadence Learning and Support portal, see the Support page.
To stay up-to-date with the latest news and information about Cadence training and webinars, subscribe to the Cadence Training emails.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
 Online Courses Online Courses
Virtuoso Layout Pro: T1 Environment and Basic Commands (L)
Virtuoso Layout Pro: T2 Create and Edit Commands (L)
Virtuoso Layout Pro: T3 Basic Commands (XL)
Virtuoso Layout Pro: T4 Advanced Commands (XL)
Virtuoso Layout Pro: T5 Interactive Routing (XL)
Virtuoso Layout Pro: T6 Constraint-Driven Flow and Power Routing
Virtuoso Layout Pro: T7 Module Generator and Floorplanner (XL/GXL)
Virtuoso Layout Pro: T9 Virtuoso Design Planner
 Blogs Blogs
Virtuosity: Synergize with CLE - Work Concurrently Across Geographies
Virtuosity: Concurrently Editing a Hierarchical Cellview
Virtuoso: The Next Overture – Concurrent Layout – a New Methodology for Team Design
 Rapid Adoption Kit Rapid Adoption Kit
 User Guide User Guide
Virtuoso Concurrent Layout User Guide
For any questions, general feedback, or even if you want to suggest a future blog topic, write to custom_ic_blogs@cadence.com.
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars that are available in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material, on a regular basis. Subscribe to receive email notifications about our latest Custom IC Design blog posts.
Baby Ravi
