  3. Quantus Assistant: Your AI Copilot for RC Extraction
JentilTom
JentilTom
Cadence Quantus Copilot
Quantus Extraction Solution
qrc
Quantus
Assisted Flows
Virtuoso Layout Suite
11 Apr 2026 • 5 minute read
Have you ever been deep into Quantus RC extraction, staring at logs or manuals, wondering:
"Where exactly is this explained?"
"Am I using the correct settings for this flow?"
"Why does closing extraction always feel harder than it should?"
If that sounds familiar, you're not alone. As designs get more complex, the pressure to close RC extraction faster—and correctly—keeps growing. That's exactly where Quantus Assistant, also known as Quantus Copilot, steps in.
What Is Quantus Assistant?
Quantus Assistant is an AI-driven knowledge companion that answers questions about Quantus tool usage and RC extraction flows via natural language queries. Powered by the Cadence JedAI (Joint Enterprise Data and AI) platform, Quantus Assistant intelligently searches across available Quantus documentation and delivers a consolidated, easy-to-consume response — complete with source references.
Think of Quantus Assistant as your 24X7, AI-powered guide inside the Quantus ecosystem—Just ask your question in natural language and get a clear, customized, to-the-point answer, backed by the latest documentation, so you can promptly get the support you need with your task at hand— design closure.
No manuals. No document hunting. No guessing which option applies to your flow.
See It in Action: Watch the Quantus Assistant Demo
We've created a short demo video now available on the Cadence ASK portal that walks through Quantus Assistant in action. Learn how both the terminal and GUI workflows can be used to answer real-world questions and see how the responses are relevant, structured, and accurate.
Quantus Assistant: AI‑Driven Workflow Assistance (Video)
Flexible Access: TUI or GUI
After the JedAI server is set up, Quantus Assistant can be accessed in two convenient ways, depending on your preferred workflow.
1. Terminal User Interface (TUI)
If you prefer working in the terminal, you can launch Quantus Assistant directly using quantus_copilot
After authenticating with your login credentials, you can simply ask questions like:
  • What is the purpose of the extracted view TRP file?
  • How do I perform layer fracturing in RC extraction?
The response is neatly organized into:
  • Quantus Copilot Response – The direct answer
  • Sources – Links to the exact documentation sections
  • Follow-Up Questions – Related queries you may want to explore next
This structured format makes it easy not just to get an answer, but to understand the context behind it.
2. Graphical User Interface (GUI)
For a more visual and interactive experience, the GUI mode is a great choice—especially for new users. The GUI can be launched:
  • From the command line using: quantus_copilot -gui
  • From the standalone Quantus UI
  • Or directly from Virtuoso Studio Layout Suite XL
Quantus Assistant GUI
The GUI opens as a chat-based interface with clickable source references and suggested follow-up questions, making deeper exploration effortless—without switching contexts.
Key Capabilities that Add Real Value
Quantus Assistant is designed to deliver relevant answers, not generic responses. Some of its key capabilities include:
  • Natural language question and answering across Quantus documentation
  • Multi-document search and synthesis for cohesive responses
  • Citation and traceability to original sources
  • Context-aware summarization of complex topics
  • User authentication for controlled access
  • User category selection to scope responses to relevant documentation
  • Customizable LLM settings in GUI mode for advanced control
Together, these features transform static documentation into an interactive, intelligent knowledge base that supports everyday extraction tasks.
Sign Off with Confidence
Quantus Assistant is more than just an AI feature—it's a productivity multiplier. By bringing fast, accurate, and context-aware answers directly into your Quantus and Virtuoso workflows, it helps you move through RC extraction with greater confidence and efficiency.
So the next time you have a question, don't search. Ask.
Take the Accelerated Way
The faster you finish your online training, the sooner you can claim your Digital Badge. Want to know how accelerated learning works? Our video walks you through the pre-quiz, navigation, and essential features. This is just the beginning. We're regularly adding new Accelerated Learning titles. Accelerated Learning courses are marked with this symbol  in our Learning Maps.
Product
Page
Related
Courses
Quantus Transistor-Level T1: Overview and Technology Setup
Quantus Transistor-Level T2: Parasitic Extraction
Quantus Transistor-Level T3: Extracted View Flows and Advanced Features
Pegasus Verification System
Related
Blogs
Intelligent Custom Signoff Closure with the Quantus Insight Solution
Training Insights Accelerated Learning–The More You Know, the Faster You Go
Your Skills Deserve a Passport: Showcase Your Expertise with Digital Badges
Do You Have Access to the Cadence ASK Portal?
  • On the Cadence ASK portal, select Register Now and provide the requested information on the Registration page.
  • If you need help with registration, contact support@cadence.com.
To stay up-to-date with the latest news and information about Cadence training and webinars, subscribe to the Cadence Training emails.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material on a regular basis. Subscribe to receive email notifications about our latest Custom IC Design blog posts.
Jentil K Tom, on behalf of the Cadence Training Team
