  3. Voltus Voice: Multi-Chiplet Marvels - Harnessing Power by…
neo
neo
Early Rail Analysis
system in package
Innovus Implementation System
Integrity 3D-IC Platform
3D-IC
IRdrop
system planning
Multi-Chiplet Design
Voltus Voice: Multi-Chiplet Marvels - Harnessing Power by Early Analysis of 3D-IC Designs
4 Jul 2023 • 5 minute read
 Voltus IC Power Integrity Solution is a power integrity and analysis signoff solution that is integrated with the full suite of design implementation and signoff tools of Cadence to deliver the industry’s fastest design closure flow. The aim of this blog series is to broadcast the voices of different experts on how design engineers can effectively use the diverse Voltus technologies to achieve high-performance, accuracy, and capacity for next-gen chip designs.
The three-dimensional integrated circuit (3D-IC) technology revolutionizes the way we build our electronic marvels. In the domain of 3D-IC, chips and chiplets/die are stacked and interconnected, pushing the boundaries of power, performance, and efficiency.
It can be likened to a skyscraper for your gadgets, where every level brings astounding functionality. To serve the needs of continuous performance growth, building devices in the third dimension is becoming a widely accepted solution to reach "More than Moore."
While the benefits of the 3D-IC technology are significant, power analysis across multiple chiplets and into the system-level design presents new challenges. In this mini-series on 3DIC, we will delve into the 3D-IC design challenges and requirements, early exploration of power profiles of stacked dies before final implementation, power integrity signoff in 3DIC designs, and chip-centric thermal analysis.
3D-IC Early Power Integrity Analysis Challenges
3D-IC power integrity design is far more complex than the flat chip. Traditionally in 2D designs, Voltus Early Rail Analysis (ERA) has the ability to perform IR-drop analysis in the floorplanning stage. This requires designers to provide the power-grid planned design and current regions for power assignment. Such power estimation methods for 2D-ICs may not accurately capture the power characteristics for three-dimensional designs. In a 3D-IC design, three-dimensional power assignment, die stacking, inter-die connection, TSV planning, and combination of power grid in each die are all factors that a designer needs to consider. To design these factors, verifying the power integrity at the floorplan stage is no longer early enough. We need to analyze the rail during the system planning stage, even before any bumps are positioned or power grid is prepared.
One-Stop Shop: Introducing an Integrated Solution for ERA
The power delivery network that transports current to each die and across to other dies is one of the most significant aspects of 3D-IC. The performance of 3D-IC designs is heavily dependent on the power allocation, distribution, and IR drop effects among multiple dies. To design a 3D-IC, the design team needs to consider the three-dimensional aspect, which makes the design of stacking and inter-die net connections as critical steps. The high-capacity Integrity 3D-IC design and analysis platform, built on the infrastructure of Cadence’s leading InnovusTM Implementation System, is a valuable tool that aids in planning the 3D-IC system.
Here's a diagram illustrating the integrated solution for early rail analysis of 3D-IC designs:
The unified solution with the Integrity 3D-IC Platform, Innovus Implementation System, and Voltus IC Power Integrity Solution offers power grid optimization with early rail analysis and IR-aware implementation for individual dies and 3D-ICs.
  • Integrity 3D-IC provides an easy-to-use GUI and Tcl commands interface, enabling designers to define the die substrate, die dimensions, power/ground networks, inter-die power/ground connection, and the stack of the dies. The platform manages most of the design data, including the power grid (PG) structure for each die.
  • Innovus uses this PG structure information to generate the multi-die power delivery network. To quickly generate the power-ground network, the flow uses our patented pattern-based formal description language for describing the power/ground routing structure in an integrated circuit design. This unique technology allows you to specify the routing pattern of the PG for each die, giving a holistic view of the power grid of a chip. Innovus generates the DEF files with PG network for each die based on the PG structure information.
  • Voltus uses these inputs to run a full simulation, attach power terminals, create virtual pads and pseudo TSVs, and generate region-based power data. You can analyze the results of this multi-die ERA analysis flow to check whether the IR drop results meet the criteria or if further design optimization is required.
A Simplified Approach for Vertical Integration
Bumps and TSVs are used as vertical interconnects between chips. The quantity and placement of these TSVs and bumps have a significant impact on the reliability of the 3D-IC power grid. During the system design phase, it is imperative for designers to consider the required quantity or density of bumps and TSVs in different regions rather than precisely placing each TSV and bump. To optimize the number of TSVs and bumps, multiple iterations are often required. Each time the PG structure needs to be modified, the DEF file generation may take a considerable amount of time. However, Voltus provides an easy approach. By defining the number of bumps for different regions, Voltus can generate virtual bumps and establish connections between inter-die bumps if necessary. In the case of bumps located on the backside metal, pseudo TSVs are created to facilitate the connection between the backside metal and the frontside metal.
To Sum it Up
By getting early feedback from the 3D-IC ERA flow, designers can get the benefits of a robust power delivery structure and avoid over-design of individual chiplets. Through the Voltus 3D-IC ERA flow, you can complete system planning, PG specification, and rail analysis in one go, eliminating the need to handle the scripts and commands in multiple-point tools. This multi-chiplet design flow can significantly help shorten the time to tapeout without sacrificing design performance.
  RAKs
ERA Flow Using Integrity 3D-IC Platform
 Product Manuals
Integrity 3D-IC User Guide
  Blogs
  • Heterogeneous Integration (HI) vs System on Chip (SoC) – What’s the Difference?
  • Introducing the Integrity 3D-IC Platform for Multi-Chiplet Design
For more information on Cadence digital design and signoff products and services, visit www.cadence.com/go/voltushs.
About Voltus Voice
“Voltus Voice” showcases our product capabilities and features and how they empower engineers to meet time-to-market goals for the complex, advanced-node SoCs that are designed for next-gen smart devices. In this monthly blog series, we also share important news, developments, and updates from the Voltus space.
