  2. Installation
  3. Troubleshooting installation of free student license installation...
  • State Verified Answer
  • Subscribers 8
  • Views 10482
Troubleshooting installation of free student license installation (with license text file)
Colinda
Colinda over 3 years ago
When requesting a free student license, a license text file is provided (or 2 in the case of Fine Marine).
  1. Go to the Admin Tool as installed together with the product of your choice (Omnis v5.2 or Fine Marine v10.2-2).
  2. In the License management section select Activate from license file(s).
  3. Select the license file(s) as received by email.
  4. Click on Activate.
  5. The License server tab in the same section should indicate that the server is up.
    • yes: the software should start. If that's still not the case, go to the Diagnostics section and check what else could be wrong.
If all this does not help, please make a new forum post with the description of what happens in your case in the above steps.
Mention also:
  • the OS version,
  • the software version,
  • The startup log when launching the software through command line:
    • Linux: omnis5.2 -print > startup_log.txt
    • Windows:  cd "c:\Program Files (x86)\NUMECA Software\Omnis 5.2"    and then:  omnis.bat -print > startup_log.txt
      Then share startup_log.txt
Screen captures may also help to illustrate the situation and get a fast response. Make sure not to show confidential information in the screen captures though.
  • Colinda
    Colinda over 3 years ago in reply to SURYA45 +2 verified
    In the email with the subject line " Your access to Cadence CFD software " you are requested to send in reply the machine identification: the hostid and hostname. This information is given at the end of…
  • Colinda
    Colinda over 3 years ago in reply to AnasY +2 verified
    Your request in the form was only for the Internal- and external flow package, not for Fine Marine. Please submit a new request through www.numeca.be/academic-students and select the Marine package.…
  • SURYA45
    0 SURYA45 over 3 years ago
    Dear Colinda,
    I am facing some problems with activation. After registering for the CFD class, I got 2 mail from your team. One from you with "DOWNLOAD-AREA" and another one with the subject line "Your access to Cadence CFD software". In both mail, I didn't find the license file as you mention in the above process. after installing the software, I found, one license file in C:\ numeca_Software\ License_management-20221021-184733\ any. license
    but when I selected this file in License management section and select Activate from license file(s) it failed.
    Please help me. I was trying to activate the FINEmarine tool.
  • Colinda
    +1 Colinda over 3 years ago in reply to SURYA45
    In the email with the subject line "Your access to Cadence CFD software" you are requested to send in reply the machine identification: the hostid and hostname. This information is given at the end of the installation process but it is also available in the Admin Tool on the Product (de)activation tab. Actually that info is in the window that is in your screenshot. Based on that information you will receive a license file.
    I am not sure which request is yours but based on your alias I can guess and think that we have only received a request for Omnis, not for Fine Marine.
    For the CFD class, Fine Marine is not needed. If you do wish to use Fine Marine in addition to your participation in the online CFD class, please make sure to clarify the purpose of use of Fine Marine in the project description field. As you have already submitted a request, please send an email to academic-cfd@cadence.com to confirm the scope of your license request.
    • Vote Up +2 Vote Down
  • SURYA45
    0 SURYA45 over 3 years ago in reply to Colinda
    Thank you for the details information. Actually, I already send mail on academic@numeca.de ID but I will send another mail in a new ID as you mention in the above mail. (Please, Don't consider the previous mail as didn't mention the reason for FINEmarine. )
    Thank you
  • AnasY
    0 AnasY over 3 years ago
    Dear Colinda,
    I got 1 license text file and activated Omnis, however i did not get a 2nd license text file to activate Fine Marine. Also in the installation guide (picture below from FINEMarine-installation.pdf) it says on page 15, point 8. b, that im supposed to find "license.info" (which i have and send to you after which you send me 1 license text file) and "license_isis.info" which i did not find after installing Fine Marine, is this problematic? Can i request a 2nd license text file for Fine Marine by sending an e-mail to academic-cfd@cadence.com?
    Best Regards,
    AnasY
  • Colinda
    +1 Colinda over 3 years ago in reply to AnasY
    Please submit a new request through www.numeca.be/academic-students and select the Marine package. Make sure to fill in all fields including the project description justifying the need for Fine Marine.
