  2. Installation
  3. Problem in opening OMNIS5.2 Student Version : Open GL older...
  • State Verified Answer
  • Replies 18
  • Subscribers 9
  • Views 22933
Problem in opening OMNIS5.2 Student Version : Open GL older version
ASGer
ASGer over 3 years ago
As mentioned on the title, when i try the student version of Omnis to open on my PC (Windows 10) its telling me the Open GL version is older although I have OpenGL 4
Below is my computer version
  • Colinda
    Colinda over 3 years ago in reply to ASGer +1 verified
    Hi ASGer, You need a license file? In the instruction email with the subject line " Your access to Cadence CFD software" you find the information how to get the hostid and hostname. Send that information…
  • judysusan
    judysusan over 3 years ago in reply to Maxiherr +1 verified
    Hi Maxi, In the command prompt go to the location of your omnis5.2 installation and just run the command mentioned. I did a local installation on myside for you to refer to. The location of your installation…
  • judysusan
    judysusan over 3 years ago in reply to Anuhya +1 verified
    Hello Anuhya, This is mostly a configuration difference on your side. Please check with the "Open With" Option. Right Click on the script file. Click on 'Properties' In General tab, If 'Open…
  • judysusan
    0 judysusan over 3 years ago
    Hello ASGer,
    Looking at your issue indeed it seems OpenGL version is right.
    What you could try doing is at the root of the installation of omnis5.2 there is a opengl32.dll file present. Could you try to copy it under the bin directory. (omnis5.2/bin)
    Then try to run the software and let me know how it goes for you.
    Regards
    Judy
  • ASGer
    0 ASGer over 3 years ago in reply to judysusan
    No difference, its showing the same error as before
  • judysusan
    0 judysusan over 3 years ago in reply to ASGer
    Hello ASGer,
    Could you try to run the application omnis5.2 using the flag "-noOpenGLCheck".
    Steps to procced with:
    1. Open Command prompt.
    2. Go to the installation folder of omnis5.2
    3. run the following omnisClient.bat -noOpenGLCheck
    4. This will avoid looking for OpenGL and the GUI should be open.
    Let me know the outcome and if this still blocks you to start omnis5.2
    Judy
  • ASGer
    Hi Judy
    Now atleast the GUI opens up, what is missing is now the license , its showing me an error about license, asking for activation key , not sure which one is it ?
  • Colinda
    +1 Colinda over 3 years ago in reply to ASGer
    Hi ASGer,
    You need a license file? In the instruction email with the subject line "Your access to Cadence CFD software" you find the information how to get the hostid and hostname. Send that information in reply to the email. Then we'll be able to send you the license and the instructions how to use it to start the license server on your computer.
    Kind regards,
    Colinda
