  2. Installation
  3. Problem in opening OMNIS5.2 Student Version : Open GL older...
  • State Verified Answer
  • Replies 18
  • Subscribers 9
  • Views 23322
Problem in opening OMNIS5.2 Student Version : Open GL older version
ASGer
ASGer over 3 years ago
As mentioned on the title, when i try the student version of Omnis to open on my PC (Windows 10) its telling me the Open GL version is older although I have OpenGL 4
Below is my computer version
  • Colinda
    Colinda over 3 years ago in reply to ASGer +1 verified
    Hi ASGer, You need a license file? In the instruction email with the subject line " Your access to Cadence CFD software" you find the information how to get the hostid and hostname. Send that information…
  • judysusan
    judysusan over 3 years ago in reply to Maxiherr +1 verified
    Hi Maxi, In the command prompt go to the location of your omnis5.2 installation and just run the command mentioned. I did a local installation on myside for you to refer to. The location of your installation…
  • judysusan
    judysusan over 3 years ago in reply to Anuhya +1 verified
    Hello Anuhya, This is mostly a configuration difference on your side. Please check with the "Open With" Option. Right Click on the script file. Click on 'Properties' In General tab, If 'Open…
  • Maxiherr
    0 Maxiherr over 3 years ago in reply to judysusan
    Hi Judy,
    I only can find the omnisClient.bat but without the -noOpenGLCheck. Have you and advices for me where to find this one.
    Tanks
    Maxi
  • judysusan
    0 judysusan over 3 years ago in reply to Maxiherr
    Hello Maxi,
    Not sure I understand right. -noOpenGLCheck is a flag command to run the Omnis software when there is issue with OpenGL version.
    If you are able to run and get the gui without the flag then it is well good. We do not usually advice to use the flag unless there is a OpenGl issue. Please follow the steps if GUI shows OpenGl version error.
    1. Open Command prompt.
    2. Go to the installation folder of omnis5.2
    3. run the following omnisClient.bat -noOpenGLCheck
    4. This will avoid looking for OpenGL and the GUI should be open.
    Do let me know if you still have issue.
    Judy
  • Maxiherr
    There is an issue with the OpenGL version. But I got the Problem, that I still don't know how to go to the omnis folder when running the Command prompt.
  • judysusan
    +1 judysusan over 3 years ago in reply to Maxiherr
    Hi Maxi,
     In the command prompt go to the location  of your omnis5.2 installation and just run the command mentioned. I did a local installation on myside for you to refer to. The location of your installation will be different.
    You can also go to the location of your installation from File explorer and on the location bar on top type " cmd " to open the command prompt form that location and then run the mentioned command.
    Thanks & Regards
    Judy
  • Anuhya
    0 Anuhya over 3 years ago in reply to judysusan
    Hello, Judy
    Even I had trouble in opening the GUI and I followed the above mentioned step to open the GUI, but if I try to open it in normal way .vbs file is opening. Could you please help me with this.
    With regards,
    Anuhya
