  2. Installation
  3. Problem in opening OMNIS5.2 Student Version : Open GL older...
  • State Verified Answer
  • Replies 18
  • Subscribers 9
  • Views 23322
Problem in opening OMNIS5.2 Student Version : Open GL older version
ASGer
ASGer over 3 years ago
As mentioned on the title, when i try the student version of Omnis to open on my PC (Windows 10) its telling me the Open GL version is older although I have OpenGL 4
Below is my computer version
  • Colinda
    Colinda over 3 years ago in reply to ASGer +1 verified
    Hi ASGer, You need a license file? In the instruction email with the subject line " Your access to Cadence CFD software" you find the information how to get the hostid and hostname. Send that information…
  • judysusan
    judysusan over 3 years ago in reply to Maxiherr +1 verified
    Hi Maxi, In the command prompt go to the location of your omnis5.2 installation and just run the command mentioned. I did a local installation on myside for you to refer to. The location of your installation…
  • judysusan
    judysusan over 3 years ago in reply to Anuhya +1 verified
    Hello Anuhya, This is mostly a configuration difference on your side. Please check with the "Open With" Option. Right Click on the script file. Click on 'Properties' In General tab, If 'Open…
  • judysusan
    0 judysusan over 3 years ago in reply to Anuhya
    Hello Anuhya,
    Just to be sure, when you click on the omnis5.2 icon on the desktop the gui does not start instead the Notepad++ opens?
    Few things we could try:
    1. Please try to double click on the omnis5.2 icon on desktop or double click on omnis.vbs file in the installation folder. (do not open in Notepad++)
    2. In windows, Click the Start button, and then search for Run and click Run. Enter the path for the omnis.vbs file
    Ex: "C:\Users\XX\AppData\Local\NUMECA Software\OMNIS 5.2\omnis.vbs" (For you the location might be different based on your installation)
    Click on OK to see if the gui tries to start.
    Did you try to open the application as per the suggestion mentioned in above using command prompt omnisClient.bat -noOpenGLCheck
    Let me know how it goes.
    Thanks & Regards
    Judy
  • Anuhya
    0 Anuhya over 3 years ago in reply to judysusan
    Hello Judy,
    Yes when I try to open Omnis5.2 icon through desktop a notepad++ file opens.
    I tried the command omnisClient.bat -noOpenGLCheck in command prompt and I could open the application.
    As you suggested I tried to open the omnis.vbs file by double clicking but again the Notepad++ is opening. I tried to change the name after that it is asking select app to open the .vbs file.
    I even tried the second option i.e. to open it through run but it's giving this error
    Because of this issue I haven't closed application which I opened using the command prompt.
    Please let me know how to solve this problem, so that I can continue working on the exercises and software.
    With regards,
    Anuhya
  • judysusan
    +1 judysusan over 3 years ago in reply to Anuhya
    Hello Anuhya,
    1. Right Click on the script file.
    2. Click on 'Properties'
    3. In General tab, If 'Open With' options shows 'Notepad' then please change it to "Microsoft Windows Based Script Host"
    4. And now you can see your txt file working as a vbs file.
    Make sure that it shows "Microsoft Windows Based Script Host" and not Notepad++.
     Thanks & Regards
    Judy
  • Anuhya
    Hello Judy,
    Thank you for the help, made changes as per your suggestion.
    With regards,
    Anuhya
  • Maxiherr
    0 Maxiherr over 3 years ago in reply to judysusan
    Hey Judy,
    It hast worked until yesterday to open Omnis with your instruction above, but now I'm again getting the window where stands, that my OpenGL Version is too low although I tried to run Omnis with no OpenGL Check... have you any solutions for that? I would be happy for and advice.
    Thank you and regards
    Maxi
