  2. Installation
  3. Problem in opening OMNIS5.2 Student Version : Open GL older...
  • State Verified Answer
  • Replies 18
  • Subscribers 9
  • Views 23322
Problem in opening OMNIS5.2 Student Version : Open GL older version
ASGer
ASGer over 3 years ago
As mentioned on the title, when i try the student version of Omnis to open on my PC (Windows 10) its telling me the Open GL version is older although I have OpenGL 4
Below is my computer version
  • Colinda
    Colinda over 3 years ago in reply to ASGer +1 verified
    Hi ASGer, You need a license file? In the instruction email with the subject line " Your access to Cadence CFD software" you find the information how to get the hostid and hostname. Send that information…
  • judysusan
    judysusan over 3 years ago in reply to Maxiherr +1 verified
    Hi Maxi, In the command prompt go to the location of your omnis5.2 installation and just run the command mentioned. I did a local installation on myside for you to refer to. The location of your installation…
  • judysusan
    judysusan over 3 years ago in reply to Anuhya +1 verified
    Hello Anuhya, This is mostly a configuration difference on your side. Please check with the "Open With" Option. Right Click on the script file. Click on 'Properties' In General tab, If 'Open…
  • judysusan
    0 judysusan over 3 years ago in reply to Maxiherr
    Hello Maxi,
    If omnis was working till yesterday do you know what has been major changes occurred since then, like Windows update that occurred recently, any new installation. reinstallation of the software or anything that could probably cause the issue.
    Also does using -noOpenGlCheck flag does not work for you?
    Judy
  • Maxiherr
    0 Maxiherr over 3 years ago in reply to judysusan
    Hello Judy,
    as I know, there haven't been any major updates or any changes on my PC-setup. I have also restarted my system, which didn't helped.
    Using the flag noOpenGLCheck hast worked until the Day I was trying to open Omnis. Now I'm again getting the message that my OpenGL Version is too low, although I was using the flag command.
    Thank you
    Maxi
  • judysusan
    Hi Maxi,
    Could you make sure there is no typo mistake when you add the flag -noOpenGLCheck.
    run the following omnisClient.bat -noOpenGLCheck
    Could you verify again and see if this works well?
    Judy
