  3. Pin order of a PMOS in layout cannot match with schemat...
  • Subscribers 130
  • Views 16995
Pin order of a PMOS in layout cannot match with schematic
naderi
naderi over 14 years ago
 Hello all,
I have a simple inverter, which has one NFET( multiplicity=1 ) and one PFET ( multiplicity=2) as shown in the attached figure .
I used virtuoso-XL to draw the layout and Assura for LVS and QRC.
Dispite of similar layout, Assura-QRC shows the pin order of two pfet trransistors are not match after extraction. The extracted sp netlist is :
MT1    Y    A    vssd!    vssd!    nfet    L=0.12U    W=0.16U ....
MavD172_1    vddd!    A    Y    vddd!    pfet    L=0.12U    W=0.16U ....
MavD172_2    Y    A    vddd!    vddd!    pfet    L=0.12U    W=0.16U .....
Rotating, or mirroring of the pfet in the layour cannot fix the problem. The problem causes LVS mismatch and cannot be fixed by changing the pin order in the schematic.
Why similar layouts are extracted differently, and is there any fix for that?
Ali
icfb.exe version 5.1.0 06/20/2007
sub-version 5.10.41_USR5.90.69
ASSURA sub-version 3.2_USR2, 2008-12-18-0841
  • Quek
    Quek over 14 years ago
    Hi Ali
    Thank you for the excellent problem description. : )  Would you please try adding a swapPins expression as shown below and see if it helps in resolving the problem?
    Best regards
    Quek
  • naderi
     Thanks Quek for your reply and effort for showing the comment using a figure.
    Here is the LVS report that is insensitive to the swapPins expression. It was tried with autoPinSwap (general) enabled and disabled. Also, pfet_m0(sch) has the same pinout as pfet_m1(lay). However, they are shown as unmatched instances.
    ========================================================================[inv1x]
    ====== Bad Initial Net Bindings (nets don't match) ============================
    = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (badbind 1)
    Schematic Net:  A
    S      *1   of pfet_m0 G
    S      *1   of nfet_m0 G
    Layout Net:  A
    L      *1   of nfet_m0 G
    L      *1   of pfet_m1 ?G
    = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (badbind 2)
    Schematic Net:  Y
    S      *1   of pfet_m0 {D S}
    S      *1   of nfet_m0 {D S}
    Layout Net:  Y
    L      *1   of nfet_m0 {D S}
    L      *1   of pfet_m1 ?{S D}
    = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (badbind 3)
    Schematic Net:  vddd!
    S      *1   of pfet_m0 B
    Layout Net:  vddd!
    L      *1   of pfet_m1 ?B
    ====== Problem Schematic Nets (no exact match in layout) ======================
    S
    S ?vddd!
    S       1   of pfet_m0 {D S}
    S       1   of pfet_m0 B
    S
    S ?Y
    S       1   of nfet_m0 {D S}
    S
    S ?A
    S       1   of pfet_m0 G
    S       1   of nfet_m0 G
    ====== Problem Layout Nets (no exact match in schematic) ======================
    L
    L ?Y
    L       1   of nfet_m0 {D S}
    L       1   of pfet_m1 ?{S D}
    L
    L ?A
    L       1   of nfet_m0 G
    L       1   of pfet_m1 ?G
    L
    L ?vddd!
    L       1   of pfet_m1 ?B
    ====== Unmatched Schematic Instances ==========================================
    = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (schinst 1)
    Schematic Instance: T0  pfet_m0
    S Pin        Net
    S ---        ---
    S D          Y
    S G          A
    S S          vddd!
    S B          vddd!
    ====== Unmatched Layout Instances =============================================
    = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (layinst 1)
    Layout Instance:    avD172_1  pfet_m1
    L Pin        Net
    L ---        ---
    L G          A
    L S          vddd!
    L D          Y
    L B          vddd!
    ====== Summary of Errors ======================================================
    Schematic  Layout     Error Type
     3          3         Bad Initial Net Bindings
     1          1         Unmatched Instances
    ====File: inv1x.cps
    ; autoPinSwap() results for schematic network.
    ====File: inv1x.cfr
    The LVS run "inv1x" has completed successfully.
    Compare problems were detected in 1 cells.
       1 cells had device mismatches.
       1 cells had nets mismatches.
       0 cells matched
    No Extraction Problems were detected.
