  2. AWR Design Environment
  3. How do I install and configure the License AWR - University...
  • Subscribers 25
  • Views 14737
How do I install and configure the License AWR - University Program?
SimTech
SimTech over 2 years ago
Once you receive an email with product and license assignment after registering on Cadence system, follow the steps below to use it.
1.  Download, install, and start the software. Click OK on the following dialog.
2.  In the AWR License Configuration dialog box, click the Configure button to display the License Configuration dialog box.
3.  In the License Configuration dialog box, select Single User License. Enter your Cadence account email and password then click Download.
4.  A status window displays the license generation and download progress. The entire process can take several minutes. When the download is complete, a new dialog box displays to indicate that your single user license is ready. Click OK to close the dialog box. The license is now set up.
5.  Once you are properly configured the AWR License Configuration dialog should show “Running with Cadence SUL licensing”.
Team SimTech
Cadence Design Systems
  • NH202410174811
    NH202410174811 over 2 years ago
    Hi - I am getting this error even though license configuraiton manager says license is upto date:
    Version: 17.04r build 17603 Rev1 (a31ec39df)
    OS: Microsoft Windows 10 (or greater)Enterprise Edition, 64-bit (build 19045)
    Features:
    Configuration: Running with AWR licensing
    AWR Configuration
    not configured
    Cadence Configuration
    not configured
    Cadence SUL Configuration
    SUL file :C:\Users\nauma\AppData\Roaming\Cadence\VBL\AWR\license\license.txt
    File status: found
    Last message: Failed connecting to the license service.
    Setting up license for: C:\Program Files (x86)\AWR\AWRDE\17\MWOffice.exe
    Setting up using the configured environment variables
    No product features were found using this configuration
  • OscPn
    OscPn over 2 years ago in reply to NH202410174811
    I am not sure but it seems installation issue, If you are installing SUL license, check the following link:
     Step-by-Step Guide to Download, Install, and Configure AWR Software Academic Trial Version
    If issue still not resolve file case or search for particular error on Cadence Support
  • BR202503059223
    BR202503059223 over 1 year ago
    I did the first steps but after I enter my email and password and click download, the status window will pop up for a couple of seconds and then disappear. And the software would not respond. I tried running as administrator, redownloading the program, and restarting my computer, and nothing changed. I have no idea what the issue is.
  • OscPn
    OscPn over 1 year ago in reply to BR202503059223
    File a support case on ASK:  https://support.cadence.com/
  • FS202409305519
    FS202409305519 over 1 year ago in reply to BR202503059223
    Is your issue solved yet? I am having the same issue. The pop-up window disappearing after a couple of seconds without the license even properly being downloaded.
  • OscPn
    OscPn over 1 year ago in reply to FS202409305519
    The fact that the dialog is closing without reporting the status is a known issue, and a fix to that is expected in the new release, which is probably later this month.
    To find out whether or not the process successfully completed, look for the license file you specified, either in the location you specified or elsewhere on your computer.  Also check if you have rights or not for the specified location.
    If you are not able to find it, then go through the process again and if it is unsuccessful again, email to Cadence university, with all the information.
