  3. Switch in analogLib
  • Views 17603
Switch in analogLib
Renju R Thomas
Renju R Thomas over 17 years ago
I am facing difficult in creating netlist with the switch component in analogLib.
It says, Cant switch to cell analogLib/ switch. Switch views:("schematic").
I tackled it, by changing the 'switch views' description to 'symbol'.
But it is not feasible for a large dsign with many sub circuits.
Also, i coulnt make it work properly in a small circuit as i dont know exactly about the pins and parameters of the switch.
Please help.
Thanks & Regards,
Renju
  • dmay
    dmay over 17 years ago
    You should be able to set it to "schematic symbol". Basically a list of the views to "switch" through. If it finds a schematic, it descends. If not, it looks for the symbol. You can add as many views as you need to that list. Some people use a view called "nlstop" to tell the netlister to stop at that particular view.
    -Derek
  • skillUser
    skillUser over 17 years ago
     Hi Renju,
    I would like to add to what Derek said.  The "view name list" can also be set by a .cdsenv setting:
     schematic  viewNameList string "schematic symbol"
    Remember that the list is ordered, so if the first view exists, then it is used, otherwise the next and so on.
    The Hierarchy Editor tool allows a more sophisticated control over the views to use for specific cells and instances by creating a configuration.  The netlister uses the config view to work out how to expand the design.
    Lawrence.
  • Renju R Thomas
     Thank you very much for the kind attention.
