  3. Monte Carlo Analysis: Varying Spice Model Files
  • Views 18952
Sirrius
Sirrius over 17 years ago
Hello All,
 I went through a related post on Monte Carlo analysis, but, I think I may have a different problem. This is the first time I am trying Monte Carlo, so maybe I could not understand the converstion too.
I am working on an old technology (0.6u) for a research project, but, I need to add "variations" into it to simulate the effects of process variations in current technologies.
Here is what I do:
Modify the BSIM3 ver 3.1 AMI06N.m file to simulate variations in effective length of the transistors:
*N8BN SPICE BSIM3 VERSION 3.1 (HSPICE Level 49) PARAMETERS
* DATE: Jan 25/99
* LOT: n8bn                  WAF: 03
* Temperature_parameters=Default
statistics {
    process {
        vary VTH0_INIT dist=gauss std=1
        vary XL_INIT dist=gauss std=1
    mismatch {
.MODEL ami06N NMOS (                                LEVEL = 11
+VERSION = 3.1            TNOM    = 27             TOX     = 1.41E-8
+XJ      = 1.5E-7         NCH     = 1.7E17         VTH0    = VTH0_INIT
+K1      = 0.8354582      K2      = -0.088431      K3      = 41.4403818
+K3B     = -14            W0      = 6.480766E-7    NLX     = 1E-10
+DVT0W   = 0              DVT1W   = 5.3E6          DVT2W   = -0.032
+DVT0    = 3.6139113      DVT1    = 0.3795745      DVT2    = -0.1399976
+U0      = 533.6953445    UA      = 7.558023E-10   UB      = 1.181167E-18
+UC      = 2.582756E-11   VSAT    = 1.300981E5     A0      = 0.5292985
+AGS     = 0.1463715      B0      = 1.283336E-6    B1      = 1.408099E-6
+KETA    = -0.0173166     A1      = 0              A2      = 1
+RDSW    = 2.268366E3     PRWG    = -1E-3          PRWB    = 6.320549E-5
+WR      = 1              WINT    = 2.043512E-7    LINT    = 3.034496E-8
+XL      = XL_INIT        XW      = 0              DWG     = -1.446149E-8
+DWB     = 2.077539E-8    VOFF    = -0.1137226     NFACTOR = 1.2880596
+CIT     = 0              CDSC    = 1.506004E-4    CDSCD   = 0
+CDSCB   = 0              ETA0    = 3.815372E-4    ETAB    = -1.029178E-3
+DSUB    = 2.173055E-4    PCLM    = 0.6171774      PDIBLC1 = 0.185986
+PDIBLC2 = 3.473187E-3    PDIBLCB = -1E-3          DROUT   = 0.4037723
+PSCBE1  = 5.998012E9     PSCBE2  = 3.788068E-8    PVAG    = 0.012927
+DELTA   = 0.01           MOBMOD  = 1              PRT     = 0
+UTE     = -1.5           KT1     = -0.11          KT1L    = 0
+KT2     = 0.022          UA1     = 4.31E-9        UB1     = -7.61E-18
+UC1     = -5.6E-11       AT      = 3.3E4          WL      = 0
+WLN     = 1              WW      = 0              WWN     = 1
+WWL     = 0              LL      = 0              LLN     = 1
+LW      = 0              LWN     = 1              LWL     = 0
+CAPMOD  = 2              XPART   = 0.4            CGDO    = 1.99E-10
+CGSO    = 1.99E-10       CGBO    = 0              CJ      = 4.233802E-4
+PB      = 0.9899238      MJ      = 0.4495859      CJSW    = 3.825632E-10
+PBSW    = 0.1082556      MJSW    = 0.1083618      PVTH0   = 0.0212852
+PRDSW   = -16.1546703    PK2     = 0.0253069      WKETA   = 0.0188633
+LKETA   = 0.0204965      VTH0_INIT =  0.7086        XL_INIT = 0.001)
where the changes made to the file are in bold face.
I do not get any kind of netlisting error. I make sure that my model-files in the ADE points to this file (and the similar AMI06P.m file).
I was expecting that when I generate the netlist, I should see different lenghts of the transistors, due to mismatch variation. However, I sitll see that the lengths of all the transistors mentioned in the netlist are the same.
I have referred to the BSIM3v3 manual, and it tells me that the effective length of the device is a linear function of XL
Can someone please help me with what's wrong here?
Thank you very much!
Regards
Sirrius
  • aplumb
    aplumb over 17 years ago
     The variation happens at simulation time (in Spectre), not netlisting time.  You have to run an MC sim over one or more points and examine the results to see what the actual mismatched values happen to be for a given run number.
  • Sirrius
    Thanks aplumb! I got that part of monte carlo simulation working!
    Sirrius
  • alokmnnit
    alokmnnit over 15 years ago
     Hi friends
              Can you help me? how can i perform montecarlo simulation on Virtuoso® Analog Design Environment 5.1.41? my circuit is dynamic comparator that made by using mosfet.
    Use Tools->Monte Carlo from within ADE.  You probably want to read the manual too. Look at the Analog IC->Virtuoso Advanced Analysis Tools User Guide in cdsdoc, or open <ICinstDir>/doc/aatoolsuser/aatoolsuser.pdf (Statistical Analysis chapter).
