  3. manual for virtuoso transient analysis and correct setup...
  • Views 17125
manual for virtuoso transient analysis and correct setup for read all manuals
tester
tester over 17 years ago
Dear All,
I have two questions addressed as the following:
1. I need to access the manual which tells me the details of vituoso transient analysis. What I really want is not the general procedure of how to run transient analysis, but rather the detailed setups such as those under the "options" button on the right bottom page of transient window.
2. When I click the "help" button on one of the Cadence windows, most of time I will get an error message stating that I cannot access that page. Can any one give me the details of how to setup up the HELP manual correctly?
Thanks a lot in advance and have a nice day!
  • tkhan
    tkhan over 17 years ago
    Refer to documents in the MMSIM stream folder, particularly:
    /MMSIM/doc/spectreref/spectreref.pdf
    /MMSIM/doc/spectreuser/spectreuser.pdf
    In shell, type spectre -h tran to see a description of all the things listed under "options".
    Hope this helps.
  • tester
    Dear tkhan,
    Thank you very much for your help in the first question. In the "virtuoso Analog Design environment" page, if I want to know the details about "simulation->options-analog", which manual that I need to look?
    By the way, does any one know how to solve the second problem that I posted earlier. Thanks all for the support.
  • tkhan
    Then you should refer to /IC/doc/anasimhelp/anasimhelp.pdf or type spectre -h options in terminal. A full list of help topics can be obtained by typing spectre -h in terminal, or browsing the help documents in /IC/doc and /MMSIM/doc. The 'Help' buttons will load HTML versions of the PDFs I referred you to. Every help document is available in HTML or PDF. You should learn to use 'cdnshelp'. I believe IC5x uses 'cdsdoc', which is now obsolete.
