  3. problems with display settings
  • Views 15798
Peach99
Peach99 over 17 years ago
Hi, I have a very important question about  the display setting of waveform (ADE). I know that I can change the colors in the display.drf - file, but my question is how I can set more different colors? I already know when I have more graphs as colors the line style changes automatically, but i want more then ten colors. And one another question is, how I can stop a simulation with a conditionally break. What I mean is, where I can enter a function or the like in the simulation settings, where I can define a break condition and how I can do this. For example I want to break a simulation if the graph reach a certain voltage value . Please help me! I don't know, how I can do this!
Regards
Daniel Pietsch
  • skillUser
    skillUser over 17 years ago
    Hi Daniel,
    I'm not sure if you can set more than 10 distinct colours, to my
    knowledge this is what you get, but I am not well versed in the
    many advances in Wavescan (ViVA) vs. AWD, so it may be better
    than 10.
    For stopping the simulation, you could have a VerilogA module
    and use the debugger to put a conditional breakpoint in the
    simulation (I believe).
    However, I will let others either supply details or suggest any
    alternatives.
    Lawrence.
  • Peach99
    Thank you for this answere. Please can you explain this more exactly about the Veriloga. I don`t know how I can do this. And where is the Debugger.(my english is not very good)
    Best Regards
    Daniel Pietsch
    Andrew Beckett over 17 years ago
    I'd be wary of depending on the VerilogA debugger, because it's been end-of-lifed.
    For VerilogA, you could write a model which monitored the node, and then invoked $stop or $finish to tell the simulator to end when that condition was reached.
    This is also something that is doable with SpectreMDL - but if you're an ADE user, that's probably not a good solution for you.
    For more information on VerilogA, look in the documentation, but also you may find A Designer's Guide to VerilogAMS useful as a place to learn more about the language.
    archive over 17 years ago
    You can place a file in your CWD called tracecolors.properties. List any Wavescan color in any order and wavescan will follow these.
    Samir Jafferali
