  3. a question about Abstract Generator
  • Views 15312
Nathen
Nathen over 16 years ago
I use Abstract Generator to create abstract layouts for encounter to use. But I meet a problem that is when I press "pins" or "extract" button, a window pops up, but there is no "run","cancell" and "help" buttons in this window, so I can do nothing. It is strange. Who can help me to find the reason?  Thank you all!
    Try increasing the height of the window (the form). I recall seeing this before,
    and the buttons are off the bottom of the form, and there's no scroll bar...
    It's really a bug - it may have been corrected (sorry, I can't check now) - but
    perhaps you can try resizing the height to see if they appear.
    > You received this email because you subscribed to notifications for the
    > Custom IC Design Forum. To unsubscribe, log in, go to forums, and change
    > your forum subscriptions.
    > http://staging2.cadence.com/community/forums/ForumSubscriptions.aspx
  • Nathen
     Hi, I tried to reshape the window and I can see the entire window but it still does not have these buttons. I doubt if this is caused by the layout files imported to Abstract Generator?
    Actually I quickly tried this, and I don't see the problem (in fact the buttons are on the form, and I can't resize it small enough to not see the form).
    What subversion are you using (Help->About in the abstract tool will say this)?
