  3. wavescan waveforms -> CIW?
  • Replies 9
  • Subscribers 133
  • Views 5160
markbeck
markbeck over 16 years ago
I'm trying to figure out if it's possible to create a key-binding that could be used to dump a group of wavescan waveforms to the CIW.  I know that it's possible to dump waveforms to the calculator, but I've got a bunch of custom skill code routines that work best in the CIW.
This is for the times that I've copied around waveforms between wavescan windows and I want to do some calulations on them (without having to resort to the calculator).
Optimally, this function would return a list of waveforms to the CIW.
 I've looked through the awv finder functions, but I can't find anything like this.  It's almost as though wavescan was designed to be one-way only.
Mark
    I'm not entirely sure I know what it would mean to "dump to CIW"? I presume you would mean to assign it to some SKILL variable? How would it know what variable to assign to?
    However, you can send a waveform to the calculator (hit the "wave" button in the calculator) and then you can cut and paste the calculator expression and use it in the CIW - there's nothing particularly special about evaluating expressions in the calculator. You could then assign the expressions to variables.  You could do the same in the calculator buffer, by adding "varName=" to the beginning of an expression (captured from a waveform) and then hitting the "evaluate" button.
  • markbeck
     Basically, I'm trying to create a function that would just return a list of the waveforms that are in the current wavescan window.
    You pointed out that I could just evaluate the expression that is placed in the calculator from the wavescan window in the CIW and get my waveform back. I didn't realize that this also worked when what was in the calculator was something like: "wave_132()"
    I found that the following function does what I wanted.
    procedure( GrabWS()
        let( (w_current l_wave t_wave t_expr)
            w_current = awvGetCurrentWindow()
            l_wave = car(awvGetWaveNameList(w_current))
            l_wfm = foreach(mapcar t_wave l_wave
                sprintf(t_expr "wave_%L()" t_wave)
                evalstring(t_expr)
            ); foreach
    Mark
    I don't think this would work reliably. It doesn't always generate a function to represent the waveform - it tries wherever possible to retrieve the original expression. I just tried something similar in IC613 with a quick example, and it didn't work.
    Because the graph is currently a separate process, it's a little more complicated, and so the data may not actually exist in the main Virtuoso session. There's almost certainly a function to get the data, but I think it will be private - probably wise given the changes coming in the waveform tools - we don't want to introduce unnecessary incompatibilities in user code.
  • markbeck
     So would something like this work?
    procedure( GrabWS()
        let( (w_current
                    l_WNL
                    l_wave
                    l_func
                    x_index
                    t_wave t_expr)
            l_WNL = awvGetWaveNameList(w_current)
            l_wave = car(l_WNL)
            l_func = cadr(l_WNL)
            x_index = -1;
                x_index = x_index + 1
                o_ret = errset(evalstring(nth(x_index l_func)))
                if(o_ret then
                    car(o_ret)
                else
                    evalstring(t_expr)
                ); if
            ); foreach
    ); GrabWS()
    I don't think so. I'm just boarding a plane, so I can't check, but awvGetWaveNameList() returns the indices and _names_ of the waveforms. There's no particular reason why the name of the variable should evaluate to the waveform object, which appears to be what you're doing.
    For example, if I plotted signals from the results browser, I just got the signal name. Same would happen with ADE outputs. Doing an evalstring on such a name would most likely lead to a syntax error return 'unbound (off the top of my head, without testing).
    So, nice try, but I still don't think it will work reliably - it may work in a few specific cases though, if you plotted the signals from the calculator, as this tends to give the expression as the name of the waveform.
    Sorry - spotted a mistake in my append. - meant to say "There's no particular reason why the name of the WAVEFORM should evaluate to the waveform object" (ie I should have said "waveform", not "variable")
  • markbeck
    markbeck over 15 years ago
     I realize I'm resurrecting an old thread, but I haven't found a solution to this.
    I'm now on version 6.14, but the situation hasn't improved.
    Basic problem is that I've got a waveform plotted in a waveform viewer (e.g. viva)  and I want access to it in the CIW.  It is possible to copy the waveform from viva to the calculator, so I know that the data exists somewhere. However, how can I reliably get at the data through skill calls?
    awvGetWaveNameList() returns: list of numbers for the curves and list of corresponding names.
    Unfortunately, I've found that the returned list of numbers doesn't correspond to anything that I can use to grab that waveform.
     Has anything changed with the newer versions of Cadence or is there any planned future expansion to allow access to the waveforms?
    Mark
    Hi Mark,
    I don't think anything has changed yet with respect to this. I'm hoping that we'll have an overhaul of the SKILL API for interaction with the graph sometime after IC615 (once the new graph in ViVA has bedded down) - and hopefully this is something we can add then (it will be simpler as in IC615 it's a single process, rather than split between the main Virtuoso and separate Java process).
  • ebecheto
    ebecheto over 15 years ago
    following lines shows how to externally plot the data ie. with gnuplot. Unfortunately, I was not able to differenciate from wavescan whether the data are Transient, AC, ... So you will only have data stored in the file if the curve is a transient curve. Hope it helps foreach(mapcar subWin awvGetSubwindowList(w_id) awvSetCurrentSubwindow( w_id subWin ) foreach( mapcar courbe cadr(awvGetWaveNameList( w_id)) rexCompile("/") file=sprintf(nil "./dat_%s" rexReplace(courbe "_" 1) ) rexCompile("(") file=sprintf(nil "%s" rexReplace(file "_" 1) ) rexCompile(")") file=sprintf(nil "%s" rexReplace(file "_" 1) ) awvPrintWaveform( ?output file VT(courbe) ?format "engineering") cmd=sprintf(nil "cat %s|sed \"s/time/\\#time/\" > %s.txt" file file) cmd=sprintf(nil "%s\n rm %s" cmd file) cmd=sprintf(nil "%s\n echo \"plot '%s.txt' \" > %s.gp" cmd file file) cmd=sprintf(nil "%s\n echo \"gnuplot %s.gp -persist\"" cmd file ) ;; cmd=sprintf(nil "%s\n wc -l %s.txt| 1 " cmd file) (system cmd) ))
