  3. Using spectre netlist as input to ASSURA
  • Views 17334
yoyega
yoyega over 16 years ago
this is a simple question, but it looks like I cannot find the answer to it... I have a layout view and a netlist in spectre format (no schematic, just a text file containing a netlist in spectre format). Is it possible to use ASSURA LVS to check the matching between the layout and the spectre netlist text file? or do I always need a schematic view?
Thanks and regards,
Pedro
    Assura can use schematics, CDL netlists, or Verilog netlists (or a combination). It does not directly read spectre netlists.
    If you're using IC613, you could use File->Import->SPICE to read in a spectre netlist and produce a schematic.
    Otherwise a perl script or something similar to convert your spectre netlist into CDL (which is SPICE-like) would be a way to handle this.
  • yoyega
     Hi Andrew, thank you very much for your reply. I am using IC514, so I will have to find some workaround. Regards, Pedro
  • lijulia
    lijulia over 16 years ago
     Hi, yoyega
    Unfortunately, we are using IC514 too, would you mind sharing your solution with us?
    Julia
  • lijulia
     Hi, Andrew
    I am using IC514 , and I tried to include or import .cir or .spi netlist to cadence for Assura lvs check, but failed. would you mind giving more detail instruction for this?
    Julia
  • Quek
    Quek over 16 years ago
    Hi Julia
    It seems that your issue is slightly different. You seem to be having a cdl import issue. Would you please start a new thread and provide more description on the problem? E.g. your device map file, output of "icfb -W", a small portion of your netlist with the different devices (mos, cap, res, etc), etc.
    Hi Pedro
    There are actually quite a lot of discussion on spectre-to-spice conversion in other forums. I think ultimately the answer is to use a perl script to do it. Hope that this link might help you.
    Best regards
    Quek
  • yoyega
     Hi Quek, thank you very much for the link. The truth is that I finally decided to enter a complete schematic for the LVS (sorry Julia, but as you see I cannot really help you on this)...a lot of work, but I didn't find any easier option at that moment. I will check out the link you sent me and see if I can find an easier way to do it.
    Thanks and regards,
    Pedro
