  3. How to count the number of digital gates used on my virtuoso...
  • Views 18726
How to count the number of digital gates used on my virtuoso schematic?
ericliu
ericliu over 16 years ago
I have used Cadence Virtuoso to compose a schematic which was made up of only standard digital gates from the foundry's libraries. Is there a tool that gives me the total number of gates appearing on my schematic? The schematic was composed in a hierarchical manner and I'd like to count the digital gates in all levels.
Can I also find out how many transistors are there on my schematic?
Thanks in advance.
Eric
  • skillUser
    skillUser over 16 years ago
    Hi Eric,
    One thing that you might be able to do is to find these instances based on the cellname (or perhaps the inverse, what that cell is not named).  Here's a brief example:
      cv = geGetEditCellView()
      => db:0x452bdf92
      stdCells = setof(inst cv~>instances rexMatchp("^std" inst~>cellName))
      => (db:0x452bdc12 db:0x452bdc13)
      count = length(stdCells)
      => 2
     In the example above, we are searching for a cell instance which has a cell name that starts with "std", using a regular expression match within a setof expression.  You can try searching for solutions that expand or follow the hierarchy, the way that a netlister might, in order to get hierarchical information. Also there is a "Tree" function for layouts, and solutions for schematic Tree code - search for these to get a hierarchical listing of a design.
    I hope that this code snippet and information helps you to get started.
    Lawrence.
    You could probably use code similar to Cadence Online Support Solution 11581916
    It would need a bit of tweaking (because this is just to count leaf cells) but wouldn't be too hard to modify.
