  3. Sigma Delta 1st Order parameter definition
  • Views 16251
caveman54
caveman54 over 16 years ago
Hello-
I am trying to use the vhdl sigma-delta model in the ahdl lib and have some questions relating to the cdf parameters.
What is the threshold voltage (vth)  if my input range is -1 to 1 volt?
What is the vout-high, is that the data output high or the maximom input voltage to get a data output high?
Thank You
caveman54
    First of all, the model (sigmadelta_1storder ) is in Verilog-A, not VHDL.
    The vth is the threshold for the quantizer. So if you have a signal swing of -1 to 1 V, it would most likely be 0 (which is the default).
    The vout_high parameter is the voltage level for the high level of the digital output signal from the sigma-delta. So a "1" will be at a voltage of vout_high, and a "0" will be at -vout_high volts (you may want to copy and change the model to suit your needs). The model itself is pretty straightforward to understand, even if you're not familiar with VerilogA.
