  3. Can't import techfile into abstract (IC6.1.4)
  • Views 1570
dura
dura over 16 years ago
No matter what I do to the techfile attached to the library I want to import into abstract generator, I can't get ERROR ABS-218 to go away:
"There are no vias specified in the technology file. Ensure that the selected constraint group has a ValidVias section or at least one via is specified in the standardViaDefs subsection of the viaDefs section in the technology file. In addition, ensure that the function argument is set to 'cut' for the via in the functions subsection of the layerRules section and then try again."
I am very clear in my techfile for the viaDefs, as well as specifying "cut" for the vias (though, I'm not clear which name "cut" needs to be set for, but it doesn't seem to matter which). Parts of the techfile are at the bottom of this post, but I haven't been able to find anything wrong.
I'd appreciate any ideas; this has become incredibly frustrating.
Note; for the rest of the .tf not shown, basically all of it came from a tech manager file dump (from inside virtuoso), there were just minor changes made to get all of the things abstract wanted in.
viaDefs(
standardViaDefs(
;( viaDefName layer1 layer2 (cutLayer cutWidth cutHeight [resistancePerCut])
; (cutRows cutCol (cutSpace))
; (layer1Enc) (layer2Enc) (layer1Offset) (layer2Offset) (origOffset)
; [implant1 (implant1Enc) [implant2 (implant2Enc) [well/substrate]]])
( M6_M5 METAL5 METAL6 ("VIA56" 0.3 0.3)
(1 1 (0.3 0.3))
(0.1 0.1) (0.5 0.5) (0.0 0.0) (0.0 0.0) (0.0 0.0)
; (more here not shown)
As well as:
layerRules(
functions(
( VIA56 "cut" 10 ) ; not sure if it should use cutLayer
( M6_M5 "cut" 10 ) ; or viaDefName
; plenty of others
  • Quek
    Quek over 16 years ago
    Hi dura
    I think perhaps you are using IC613. IC614 has a clearer error message. I believe that you do not have a constraintGroup named "LEFDefaultRouteSpec" in your Virtuoso techfile. You will need to have a section similar to:
    ;( group       [override] )
      ( "LEFDefaultRouteSpec"    nil
        interconnect(
         ( validLayers   (M8  M7  M6  M5  M4  M3  M2  M1  PO  ))
    ( validVias (M8_M7 M7_M6 M6_M5 M5_M4 M4_M3 M3_M2 M2_M1 M1_PO))
      ) ;interconnect
    Please refer to COS solution 11518952 for the full explanation.
    Please also refer to $CDSHOME/tools/dfII/samples/tutorial/abstract on
    the necessary info that the techfile should have.
    If you would like to use another constraintGroup instead of the default
    "LEFDefaultRouteSpec", please add the following option in the
    .abstract.options file which can be found in your library
    directory:
    absSetOption("UseConstraintGroup" "yourCG")
    Best regards
    Quek
  • Aritra
    Aritra over 14 years ago
    I am also facing similar type of problem. In abstract, when library is opened no cell is displayed. In error log it prompts as, bottom VIA layer is not mentioned.
    If I need to modify the techfile, let me know which exact file I need to modify & how.
