  3. mapping file
  • Views 17650
mapping file
sathisha
sathisha over 16 years ago
Help me how to use the mapping file to change the cells from one library to other library. In CIW -> ****_tools->Rereference standard cells is there any extension for the map file. It will be helpful with explanation how it will work and how to use. Regards Sathisha
    Hi Sathisha,
    I'm assuming that the "****" in your post was the name of a foundry or company? Whatever it was, this is some customisation to the tools and not a standard feature of Virtuoso.
    So we can't really answer it - either you have to name the **** bit and hope that somebody else on the forum is familiar with that design kit or company customisation, or you ask the provider it came from.
  • sathisha
    Hi Andrew **** is jsut tchnology name for example in CIW File Tools Options 90nm_tool/65nmtools ->Rereference standard cells I thought it was one of cadence application. Is there any extension for the mapping file for ex: file.txt file.il etc Regards Sathisha
    Hi Sathisha,
    Even so, it's still not a standard Cadence menu, so must be added by your company or design kit.
    Because I don't know what it does, I can't answer what the requirements for the mapping file are - you'll need to consult with whoever provided the mapping function.
  • sathisha
    Hi Andrew, Thanks. Regards, Sathisha
