  3. Is it possible to see a completely blank window when zoom...
  • Subscribers 136
  • Views 16753
Is it possible to see a completely blank window when zoom out?
SlimAnt
SlimAnt over 16 years ago
I am using Virtuoso Layout Editor version IC6.1.3
When I turned all the layers (except one that I don't use) to invisible and zoom out, then I will see red outlines of the devices. When I zoom in again then it disappeared.
Is it possible to turn of those red outline when I zoom out?
Steven
  • Quek
    Quek over 16 years ago
    Hi Steven
    Please go to "Options->Display" and change to a larger filter size. The default value is 6. Perhaps you can try 8 or 9.
    Best regards
    Quek
  • SlimAnt
    Yes, this works.
    I have to put 3 digit number to get the way I want it.
    Steven
    Steven,
    What this means is that it is not showing any shapes smaller than the filterSize. So why bother drawing it at all?
    There is an enhancement CCR filed by a colleague recently, number 703739, asking for a means of turning off the red boxes. So best thing is to contact Cadence Customer Support, and request the same thing - this will increase the number of requests for the same thing and that helps up the priority.
  • dmay
    dmay over 16 years ago
    That is probably not what you want to do. The filter tells Cadence how many pixels wide the data should be before Cadence will draw it. This will speed up the drawing of a cellview by not drawing very small pieces of data when zoomed out. Next to the Filter is a Style that is either "Empty", "Outlined" or "Filled". Try changing your filter back to somthing like 6 and set this Style to Empty. Alternatively, turn off the visibility of "Instance" in the LSW. Instance visibility appears in the Object section of the LSW.
    Derek
  • SlimAnt
     Those red boxes might be helpful as a guide, but sometime it could be annoying when we only want to see certain layers on screen.
    Steven
