  3. help: waiting for ipc:0 to terminate
  • Views 6086
feiyu
feiyu over 16 years ago
Hi all
When icfb startup or running, it will suddenly hang, and the CIW shows:
Waiting for ipc:0 to terminate
Sometimes it shows ipc:1, ipc:2, etc.
What happend and how to solove this problem?
Thanks to all.
Best wishes.
  • Quek
    Quek over 16 years ago
    Hi feiyu
    This is most likely related to mismatch network info. COS solution 11527850 provides some good tips on how to resolve it.
    Would you please check if the ip address shown in output of "ifconfig -a" cmd and /etc/hosts file are in sync? E.g. the following shows a conflict in the ip addresses (192.168.80.123 vs 192.168.80.128):
    === /etc/hosts ===
    # The following line might be present
    192.168.80.123 myMachine
    === ifconfig -a ===
    eth0      Link encap:Ethernet  HWaddr 00:0C:29:D3:65:6F
              inet addr:192.168.80.128  Bcast:192.168.80.255  Mask:255.255.255.0
              inet6 addr: fe80::20c:29ff:fed3:656f/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
    If the above has no problem, try kill all cdsNameServer processes and then restart icfb:
    linux>pkill cdsNameServer
    Also, just to be sure that this is not related to any scripts, you can try starting icfb using:
    unix>icfb -nocdsinit &
    Ensure that the hostname in the following 3 files is consistent:
    /etc/sysconfig/network
    /etc/sysconfig/network-scripts/ifcg-eth0
    /etc/resolv.conf
    Best regards
    Quek
  • apaj
    apaj over 12 years ago
    Who says timetravel is not possible?
    Sir, you just came all the way from 2010, full four years ago, and solved my nightmare. After three days of installing and reinstalling I finally find the solution in your post.
    What to say, but: Quek, thank you very much.
    Sincerely,
      apaj
  • Quek
    Quek over 12 years ago
    Hi apaj
    That's great. : )  You are welcome.
    Best regards
    Quek
