  3. Exporting LEF format file from layout library
  • Replies 8
  • Views 22970
shushan
shushan over 16 years ago
Hi All,
Can you please tell me if it is possible to export LEF file from the cells in current layout library in IC6.1.3? And if yes, how to do that or what other alternatives to use?Because it seems, that simple clicking on appropriate buttons don't give the desired/any result.
Thanks in Advance,
Shushanik
    Hi Shushanik,
    This ought to work. In order to find out what is going wrong, it would be useful to know:
    1. What subversion of IC613 are you using (Help->About in the CIW will tell you this)
    2. What "simple clicking" did you do - perhaps a picture of the filled in File->Export->LEF form would help
    3. Were there any errors in the CIW (or CDS.log) when you OK'd the form?
    I just tried it and it worked for me.
  • shushan
    1.  I am using IC6.1.3.500.10
    2. This is what i do:
         File-Export-LEF
    _____________________________________
    LEF File Name:abc.lef
    Library name:tsmc45
    "cells" buttom is highlited
    Output Cell:MUX2_8
    Output Views:layout
    Log File Name:abc.log
    LEF version: 5.6
    "Use GUI Fields" buttom is highlited
    __________________________________________
    No Errors occur. At first, everything seems fine. But the problem is that the generated abc.lef file does not contain information about specified MACRO. It seems that it gives information about technology file. So, imported abstract view is empty.
    Here is the only information in abc.lef about given MUX2_8 cell
    MACRO MUX2_8
      PROPERTY oaTaper "__DerivedDefaultTaperCG" ;
      PROPERTY lastSavedExtractCounter 303 ;
    END MUX2_8
    Shushanik
  • shushan
         File-Export-LEF
    Library name:tsmc45
    Output Cell:MUX2_8
    Output Views:layout
    LEF version: 5.6
    MACRO MUX2_8
    END MUX2_8
    Shushanik
  • shushan
     Pleaseeeee help me.This is realy very hot!!!!
    Do i need the abstact views of cells before exporting them as .LEF format cells.Do i need some changes to made in technology file?
    How to get comlete LEF file?
    Thanks in Advance,
    Shushanik
    If it is really hot, asking in a Community Forum is not the right place to do it. Go to Cadence Customer Support (http://support.cadence.com). The Community Forum is not a substitute for customer support - it is purely down to voluntary responses by the community (including a few of us from Cadence who do this in our spare time - for example, it is not part of my job to respond on these forums).
    My guess is that the cellViews you are trying to export are just arbitrary layout. Normally you need to have pin information on the layout, and boundaries and blockages and so on - usually things that will either have been created by hand using a tool such as Virtuoso Layout Suite XL, or by using the abstract generator.
  • shushan
    Hello Andrew,
    Thank you. I do appreciate that.
    My layout design is complete and has pins,boundary....etc.
    The only solution i can see at this point is to change technology file.Can it help?
    Shushanik
    Hi Shushanik,
    I can't see why that should be necessary (changing teh technology file).
    Best is to provide the data to Cadence Customer Support so they can take a look and find out why.
  • shushan
     OK,thank you.
